RadioFanat
Про моргалки (опыты с AGM OPTIMA)
  Цитата
The battery pack was discharged at 25 amps (nominally C/2 rate) until the voltage of a single
module went below 10.5 volts. This would be equivalent to 100% DOD or 1.75 VPC for a
single module, but was approximately equivalent to 80% DOD for the non-limiting modules.
The battery pack was then charged at 100 amps until 60% charge return, 50 amps until 80%
charge return, and 15 amps until 100% charge return. It was then overcharged with a current
interrupt (CI) technique instead of ZDV because there was no battery monitoring system. The
typical CI technique used was to apply 5 amps to the battery pack for 15 seconds and then no
current for 20 seconds. This was repeated until 3 Ah of overcharge was provided to the
battery pack. The CI charge/rest and the amount of overcharge varied depending on the age
of the battery. Further details will be given in the results and discussion.
What is a CI technique?
•= A pulsed-charge technique with on-off times of 5-30 seconds, which are adjustable so
negative-plate polarization is achieved during charge, and heat dissipation is effected
during rest.
•= It is used with thin plate batteries for the finishing charge step, particularly late in life.
•= No voltage limit is imposed during the charge steps (but gassing appears to be minimal or
nonexistent).
•= Little polarization during charge and rest voltages below 14.0 volts are used as criteria to
trigger an increase in the pulsed-current amplitude.
•= Late in life pulsed-current levels of 2C–4C may be necessary to achieve 100% recharge.
A CC charge and CI technique were used to charge the battery pack for several reasons.
•= A CC charge allows for fast recharge and use of the voltage/time curves for predictive
purposes.
•= Overcharge at continuous high currents causes thermal problems, particularly as the
battery ages when the oxygen cycle dominates.
•= Current interrupt allows use of high currents with rest periods to maximize recharge
efficiency, minimize overcharge, and reduce overall pack temperature.
•= The charge/rest rate and current for a multi-step CI must be optimized for long cycle life
for high discharge capacities.
  Invalid Date в NaN:NaN, Discoverer сказал:
1421964900[/url]' post='355642']
Подскажи какой алгоритм в автоэлектрике 1001, какие батареи поддерживает это зу. Я еще вампел 30 заказывал его привезли в наборе сделай сам, решаю нужен ли еще один.
Тут о 1001
Это как??
  23.01.2015 в 12:32, Discoverer сказал:
Инструкция то понятна, а как на деле? Будет ли он заряжать аккумулятор полностью? (подразумевается обычный АКБ 55-60 Ампер). Или это из разряда новомодных наворечнных, но бесполезных устройств. А то уже давно присматриваюсь к этому девайсу, после безвременной кончины ЗУ-75а производства Тамбова. И цена у него вполне разумная. И был ли у кого опыт эксплуатации данного устройства T1001А.
Изменено пользователем FenixVLG
  23.01.2015 в 16:16, FenixVLG сказал:
Если заряжать так как написано в инструкции - примерно 80% заряд будет от возможного.
Прмиерно тот же процент и у вымпелов (кроме50/55)/орионов/ЗУ75/Катунь и подобных без возможности заряда импульсами.
Зарядка с паузами - больше % получится.
пруф
  Цитата
Как грамотно произвести работы по десульфатации ?
Есть два способа - первый это купить умную зарядку-автомат, потому что у них есть специальный режим для таких случаев. В этом режиме зарядка дает импульсы тока примерно 1А напряжением 14.7-15В с переменной скважностью, зависящей от степени разряда (напряжением на СА) СА. Т.е. если на СА например 10В то будет импульс с частотой следования примерно 0.5-1Гц. При этоим продолжительность импульса вдвое меньше паузы. В процессе повышения напряжения на СА до 12В частота следования импульсов (а в некоторых зарядках - продолжительность(скважность) импульса тока) увеличивается пропорционально, и с 12В уже идет просто зарядка постоянным током.
Также известен способ восстановления СА батарей асимметричным током (при соотношении зарядной и разрядной составляющих тока 10:1 и отношении длительностей импульсов этих составляющих 1:2. Но этот метод обычно делается на частотах 50Гц(сеть 220В) и я его не рекомендую - так как 50Гц это "сильно быстро" и будет лишний нагрев СА. Хотя само соотношение "зарядка:нагрузка" в 10:1 (по току) я рекомендую применять для низких частот (0.5-1Гц).
Обладатели кулона 912 (дорогой зарядник, к сожалению) вполне могут реализовать вышеописанный алгоритм настройками
  23.01.2015 в 16:54, Discoverer сказал:
@Discoverer А если не по инструкции, паузами это как? Пять минут заряжаем, выключили на 5 минут, потом опять пять минут заряжаем и т. д. Или как то по другому?
тыц страницу назад
5 минут - много.
Минута/10-15 секунд перекур.
на карайняк - вот так. (эффективно)
https://www.youtube.com/watch?v=GdFf8JkX6jI
https://www.youtube.com/watch?v=DLDIQaNs6Ig
https://www.youtube.com/watch?v=p0LvPl_UFxI
  23.01.2015 в 19:38, Discoverer сказал:
тыц страницу назад
5 минут - много.
Вот это система.)
Я бы наоборот сделал. 10 секунд заряжаем, 1 минута - перекур. Иначе кипеть будет.
Реле поворотов? ))
Дешево и сердито.
  23.01.2015 в 19:53, igork сказал:
По хорошему - смотреть надо за динамикой падением напряжения в паузах.
Если слабо падает - то время заряда уменьшаем.
При больших паузах время зарядки уходит с "пятницы во вторник".
И еще - смотря какой ток заряда выставлен.
Есть видео - 30Ампер зарядный ток и АКБ нифига не кипит.
Зарядка импульсным током.
Злоупотреблять такими токами не стоит.
Тыц
Уважаемые, а может кто-нибудь сказать что-то хорошее про ЗУ HYUNDAI HY 800? Увидел тут его намедни, очень даже ничего, впечатления приятные оставляет о себе. Автоматическая 9-ти стадийная зарядка, аналогичная, судя по графику, Стеку. Стоит обратить на него внимание?
