Shell Helix Ultra ECT C2/C3 0W-30 (API SN; VW 504/507; MB 229.52/229.51/229,31; Porsche C30)
torcon
Shell Helix Ultra ECT C2-C3 0W-30 photo1.JPGShell Helix Ultra ECT C2-C3 0W-30 photo2.JPG
Спецификации: ACEA C2/C3; API SN; VW 504/507; MB 229.52, 229.51, 229,31; Porsche C30
Техническая документация: Helix_Ultra_ECT_C2_C3_0W-30_(TDS-rus).pdf
550042353 Shell Helix Ultra ECT C2/C3 0W-30 4л
550042390 Shell Helix Ultra ECT C2/C3 0W-30 1л
550046358 Shell Helix Ultra ECT C2/C3 0W-30 1л
550046375  Shell Helix Ultra ECT C2/C3 0W-30 4л
550046305 Shell Helix Ultra ECT C2/C3 0W-30 1 л. (made in Germany);
550046306 Shell Helix Ultra ECT C2/C3 0W-30 4 л. (made in Germany);
пр-во - ЮВА, Турция, ЕС.
550046641 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550046440 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550052527 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550052662 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550042351 - Shell Helix Ultra ECT C2/C3 0W-30 1л
550046405 -  Shell Helix Ultra ECT C2/C3 0W-30 4л
550053030 - Shell Helix Ultra ECT C2/C3 0W-30 4л
550068840 - Shell Helix Ultra ECT C2/C3 0W-30 4л
550046307 - Shell Helix Ultra ECT C2/C3 0W-30 5л
550042371 - Shell Helix Ultra ECT C2/C3 0W-30 5л
Shell Helix Ultra ECT C2/C3 0W-30 Made in Germany УРЦ
Shell Helix Ultra ECT C2/C3 0W-30 Made in Germany МИЦ
Shell Helix Ultra ECT C2/C3 0W-30 made in Germany 2023
Shell Helix Ultra ECT C2/C3 0W-30 свежее 2020
Shell Helix Ultra ECT С2/C3 0W-30 свежее
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Audi A5 (F5) после 2034км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на VW Tiguan 2 после 15000 км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Volkswagen POLO после 7365км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Volkswagen Touareg FL после 8500км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Skoda Octavia A7 после 12000 км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Mercedes ML350 после 10000км
Shell Helix Ultra ECT C2/C3 0W-30 отработка на Octavia 2.0 TDI после 3000км
Shell Helix Ultra ECT С2/С3 0W-30 отработка на Peugeot 308 после 4500км
Ребята такое масло можно в мазду 3 (1.6 105лс) заливать?,и если нет то пожалуйста обьясните почему!
Можно. Отличное среднезольное масло API SN, от которого двигатель будет чище, чем от полнозольного (при интервале смены до 7 тыс. км). В Азии-Америке такие и заливаются.
Но: в европейских рекомендациях стоит полнозольное масло A5/B5 для увеличения срока замены масла до 10-15 тыс.км. Но это будет к концу срока такой гуталин, поэтому всё равно более 7-8 тыс. км лучше не ездить.
Изменено пользователем Izb
Залил сегодня, наблюдал за температурой. За бортом 6 град, прогрелось очень быстро, в вялотекущей московской толкучке 101-105 град, что выше чем у несвежего Шелла 0-30 В3/В4. Погода пока нелетная, ежели удастся застать сухое полотно - проверю в других условиях :).
Я думал что только у моей машинки повышенная температура и угар на этом масле. До этого ездил на Тотал "QUARTZ INEO MC3 5W-30" до 10000 не угорало и пол щупа.
Пы.Сы. За 2500 на Шелл угарело пол щупа :(
Насчет угара я не писал. А повышенная температура - не факт что это плохо, больше тепла взяло масло => меньше тепла в омываемых маслом деталях двс. Хотя лето на этом масле под вопросом, конечно.
И заводиться стала не то что с пол оборота, а с четверти. Ключ даже отпустить не успеваю :)
Изменено пользователем sergun
Все верно, про угар Вы не писали :)
Я по незнанию процессов в двигателе наивно предположил, чем выше температура масла-тем хуже для него. Угар может появится, а может нет. Покатайтесь и напишите в теме, нам очень интересно получить о масле больше информации :)
Изменено пользователем NAK
Это было мое предположение. Может оказаться, что и хуже.. Например, если рассуждать с точки зрения удельной теплоемкости - то чем выше теплоемкость масла, то тем меньше растет температура масла с подводом теплоты к маслу. Т.е. если рассматривать 2 масла с высокой и низкой теплоемкостью, то при подводе к ним одинакового кол-ва тепла температура масла с высокой теплоемкостью вырастет меньше чем с низкой. С этой точки зрения шелл этот не очень хорош..
Вопрос насколько могут различаться теплоемкости масел на разных базах.
Наблюдать то я - понаблюдаю, осталось только потом правильные выводы сделать.
Вот и мне нужен совет по Шеллу. И вечный вопрос - Что делать?
Даже больше, у всех прошу совета и помощи  :help:
фото горловины и капельной пробы дрыгателя( может кольца залегли?)
http://www.oil-club.ru/forum/topic/945-moya-gorlovina/page-89?do=findComment&comment=531211
Похоже насчет температуры, это была моя мнительность. Вчера прохватил по сухому, на хорошем ходу показания температуры уже выглядели вполне прилично. До 100 при спокойном режиме, 102-106 при неспокойном. В предыдущий раз было много пробок => низкая эффективность работы радиаторов => выше температура масла. Полет отличный, особой разницы по сравнению с А3/В4 0-30 не заметил, единственное, С2/С3 похоже, быстрее прогревается до рабочей температуры, собственно этого и ждали.
Надо будет замутить тест на топливную эффективность :).
Прекрасно, ждем продолжения! :)
П.С. Сделайте фото горловины сейчас и перед сливом для сравнения.
на Октавии малоинформотивно
К сожалению не знаю об Октавии ни чего. Нельзя сделать фото как и во многих современных машинах по причине сеточки от камушков?
Там металлическая пластина и практически ничего не видно..
Мдя, у производителя от потребителя всегда есть что скрыть :(
Почти сутки мозгового штурма(в ДВС я ноль) наталкивают меня на мысль:
1) Шелл заявляет о супер очистке поверхности поршня
Всем известно, что химией поршень не очистить, значит нагар надо сжечь. Так они похоже повысили температуру поршня за счет худшего теплоотвода масляной пленкой. В итоге: быстрый прогрев, чистый поршень, более стабильная и низкоиспаряемая пленка масла между поршнем и стенкой цилиндра для меньшего износа
2) Наверное НОАК Шелла выше ТОТАЛА МС3 и в моем случае не сливаемые остатки ТОТАЛА(300-500 мл) при замене выпарились и вуаля ... пол щупа при пробеге в 2500 км.
Прошу на мои дурные и без толковые мысли не обращать внимания.
Уверен что выше написал глупость.
П.С. Зря я гоню на Шелл, но лучше перебдеть, чем не добдеть ;)
Если так сильно заморочились - докатайте планируемый интервал и сделайте анализ отработки, там видно будет..
