Масла SRS
Масла SRS
Официальный сайт: http://www.srs-oil.com/home-en.html
Русскоязычный сайт: http://srs-oil.ru
Список продукции: http://www.srs-oil.com/products.html
Спойлер
11000 - SRS ViVA 1 Ecosynth SAE 0W-40 1L
10262 - SRS ViVA 1 Ecosynth SAE 0W-40 4L
10195 - SRS ViVA 1 Ecosynth SAE 0W-40 200L
SRS ViVA 1 ecosynth SAE 0W-40 1л Артикул: 4033885000090
SRS ViVA 1 ecosynth SAE 0W-40 4лАртикул: 4033885000854
SRS ViVA 1 SAE 10W-40 1лАртикул: 4033885000168
SRS ViVA 1 SAE 10W-40 4лАртикул: 4033885000182
SRS ViVA 1 SLV plus SAE 5W-30 1лАртикул: 4033885000526
SRS ViVA 1 SLV plus SAE 5W-30 4лАртикул: 4033885000847
SRS ViVA 1 special F plus SAE 5W-30 1лАртикул: 4033885001189
SRS ViVA 1 special F plus SAE 5W-30 4лАртикул: 4033885001394
SRS ViVA 1 special F plus SAE 5W-30 5лАртикул: 4033885001400
SRS ViVA 1 special LMS SAE 5W-30 1лАртикул: 4033885001370
SRS ViVA 1 special LMS SAE 5W-30 4лАртикул: 4033885001011
SRS Viva 1 synthracing SAE 5W-50 1лАртикул: 4033885000489
SRS Viva 1 synthracing SAE 5W-50 4лАртикул: 4033885000861
SRS ViVA 1 topsynthalpha LA SAE 5W-30 1лАртикул: 4033885000533
SRS ViVA 1 topsynthalpha LA SAE 5W-30 4лАртикул: 4033885000540
SRS ViVA 1 topsynth SAE 5W-40 1лАртикул: 4033885000441
SRS ViVA 1 topsynth SAE 5W-40 4лАртикул: 4033885000458
7945 - SRS Viva 1 Topsynth Alpha LS 5W-40 1L
7944 - SRS Viva 1 Topsynth Alpha LS 5W-40 4L
7943 -  SRS Viva 1 Topsynth Alpha LS 5W-40 5L
7940 -  SRS Viva 1 Topsynth Alpha LS 5W-40 208L
SRS Cargolub TFG 10W-40 E4
SRS VIVA Special LMS 5W-30
SRS ViVA 1 Ecosynth Plus 0W-40
SRS ViVA 1 Synth Racing 5W-50
SRS Cargolub TLS Plus 5W-30
SRS Viva1 Topsynth Alpha LA 5W-30
SRS Viva1 Special MS 5W-30
SRS Viva1 SLV Plus 5W-30
SRS Viva1 Topsynth 5W-40
SRS Viva1 Ecosynth 0W-40
SRS VIVA 1 Topsynth 5W-40
SRS VIVA 1 topsynth Plus 5W-40 бочковое
SRS Viva1 10W-40
SRS Viva1 Longlife 5W-30
SRS VIVA 1 alpha LS 5W-40 C3
SRS Special F Eco 5W-20
SRS Getriebefluid 5 L 75W-90 API GL-4+
SRS Wiolin ATF VI
SRS Viva 1 SLV Top 5W-30 отработка на BMW 1 Series F20 после 7 648 км
SRS ViVA 1 synth racing 5W-50 отработка на Nissan GT-R после 5000км
SRS Cargolub TLS PLUS 5W-30 отработка на IVECO двиг CURSOR 13 после 18000км
SRS Ecosynth 0W-40 отработка на Infiniti EX35 после 8500км
SRS VIVA 1 topsynth SAE 5W40 API SN отработка на Citroen Berlingo NEW B9 после 7000км
SRS VIVA1 Longlife 5W30 отработка на Citroen Berlingo после 5000 км
SRS Viva1 SLV Plus 5w-30 отработка Audi Q7 2015 4M после 7500км
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A4 после 6011 км
SRS VIVA 1 Topsynth Plus 5W-40 отработка на Citroen Berlingo после 5000 км.
SRS ViVA 1 ecosynth 0w-40 отработка на Kia cerato Koup после 9500км.
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A5 3.2 TFSI после 5000 км
SRS ViVA 1 special F eco 5w-20 отработка на Kia cerato Koup после 7900км
Добрый день.
Подскажите пожалуйста есть ли отличия в маслах SRS 0W40:
1) SRS VIVA 1 ecosynth plus
2) SRS VIVA 1 ecosynth
@aSasha280, смотри техлисты,отличия есть http://www.srs-oil.com/pdf_files/srs-viva-1-ecosynth/srs-viva-1-ecosynth_170_2.pdf        http://www.srs-oil.com/pdf_files/srs-viva-1-ecosynth/srs-viva-1-ecosynth_170_2.pdf   по допускам и рекомендациям,по классификации,по вязкости,по золе.Считаю экосинт плюс более предпочтительным. Изменено пользователем kep
В теме сбора желающие пожалуйста скидывайтесь на SRS Special F Eco 5W-20 свежее,базовый плюс CCS,всего 4550
Поклонникам SRS предлагаем скидываться на анализ свежего фордовского 5W20,его еще не тестили.
Добрый день, уважаемые форумчане!
Прочитал форум, почитал про масло, только хвалебные отзывы. Подскажите пожалуйста, хочу перейти на масло SRS (тем более в южном порту есть точка которая возит оригинал). Автомобиль Мазда СХ-9 3,7л.
Все свои авто катал на мобиле 5W30, т.к. ездил только на американских V8. Сейчас пересел на мазду и удивился, примерно после 3000 пробега масло начинает угорать. Двигатель чистый. Общий пробег 40 000 миль. Двигатель кручу иногда до 6000 оборотов. Какое из масел SRS лучше лить в данный двигатель для меньшего угара.
На заливной пробке написано 5W20.
Заранее благодарен за ответы.
Изменено пользователем BigFan
@BigFan, сейчас собираем на анализ вот этого масла - оно как раз твоя тема.
35) SRS Special F Eco 5W-20 свежее Собрано:1000(закуп и отправка Antonmsk) kep(1000) elvis(300) PLM
скидываемся средствами здесь, там в шапке карта куда кидать
http://www.oil-club.ru/forum/topic/25980-skidyvaemsya-na-laboratornye-analizy-svezhih-ma/page-90
Оффтоп
Уважаемый torcon - это же масло для экобустов. А у меня другой двигатель. Но скинуться не против, а сколько надо (уж извините за тупой вопрос)?
Ну и мне масло нужно менять уже в эту субботу, думаю тесты к этому времени не будут готовы.
@BigFan, да оно для экобустов, но противоречий с ILSAC GF-5 у него не много, кроме топливной эффективности и тишины работы двигателя. :) А по скидонам, да дело добровольное кто сколько может, просто если интересно оно тебе :)
Понял. Ок. А сейчас то какое лучше залить для моего движка? я так понимаю, раз у меня расход начинается после 3000 км. примерно, то мобил теряет вязкость. Какое все таки лучше мне залить с сохранением вязкости...
Отправил на карту 500р. но сообщение за какое масло у меня в банк-клиенте написать негде. У меня не сбер.
@BigFan, от щупа бензином не воняет после этих 3000км? А то может он способствует угару масла именно после 3000км, накопившись в масле... :) Это явно не масло умирает за 3000км, а повлиять на его свойства и на вязкость при таком детском пробеге может попавшее в него топливо.
Я бы наверное начал с этого (оно тоже если что не ILSAC) SRS Viva1 Topsynth Alpha LA 5W-30
А как теперь проверить попадает ли топливо в масло. Масло зебином не пахнет!
BigFan да да все получил, спасибо за Ваше содействие :) Соберем всю сумму и проведем анализ :)
