Масла SRS
Масла SRS
Официальный сайт: http://www.srs-oil.com/home-en.html
Русскоязычный сайт: http://srs-oil.ru
Список продукции: http://www.srs-oil.com/products.html
Спойлер
11000 - SRS ViVA 1 Ecosynth SAE 0W-40 1L
10262 - SRS ViVA 1 Ecosynth SAE 0W-40 4L
10195 - SRS ViVA 1 Ecosynth SAE 0W-40 200L
SRS ViVA 1 ecosynth SAE 0W-40 1л Артикул: 4033885000090
SRS ViVA 1 ecosynth SAE 0W-40 4лАртикул: 4033885000854
SRS ViVA 1 SAE 10W-40 1лАртикул: 4033885000168
SRS ViVA 1 SAE 10W-40 4лАртикул: 4033885000182
SRS ViVA 1 SLV plus SAE 5W-30 1лАртикул: 4033885000526
SRS ViVA 1 SLV plus SAE 5W-30 4лАртикул: 4033885000847
SRS ViVA 1 special F plus SAE 5W-30 1лАртикул: 4033885001189
SRS ViVA 1 special F plus SAE 5W-30 4лАртикул: 4033885001394
SRS ViVA 1 special F plus SAE 5W-30 5лАртикул: 4033885001400
SRS ViVA 1 special LMS SAE 5W-30 1лАртикул: 4033885001370
SRS ViVA 1 special LMS SAE 5W-30 4лАртикул: 4033885001011
SRS Viva 1 synthracing SAE 5W-50 1лАртикул: 4033885000489
SRS Viva 1 synthracing SAE 5W-50 4лАртикул: 4033885000861
SRS ViVA 1 topsynthalpha LA SAE 5W-30 1лАртикул: 4033885000533
SRS ViVA 1 topsynthalpha LA SAE 5W-30 4лАртикул: 4033885000540
SRS ViVA 1 topsynth SAE 5W-40 1лАртикул: 4033885000441
SRS ViVA 1 topsynth SAE 5W-40 4лАртикул: 4033885000458
7945 - SRS Viva 1 Topsynth Alpha LS 5W-40 1L
7944 - SRS Viva 1 Topsynth Alpha LS 5W-40 4L
7943 -  SRS Viva 1 Topsynth Alpha LS 5W-40 5L
7940 -  SRS Viva 1 Topsynth Alpha LS 5W-40 208L
SRS Cargolub TFG 10W-40 E4
SRS VIVA Special LMS 5W-30
SRS ViVA 1 Ecosynth Plus 0W-40
SRS ViVA 1 Synth Racing 5W-50
SRS Cargolub TLS Plus 5W-30
SRS Viva1 Topsynth Alpha LA 5W-30
SRS Viva1 Special MS 5W-30
SRS Viva1 SLV Plus 5W-30
SRS Viva1 Topsynth 5W-40
SRS Viva1 Ecosynth 0W-40
SRS VIVA 1 Topsynth 5W-40
SRS VIVA 1 topsynth Plus 5W-40 бочковое
SRS Viva1 10W-40
SRS Viva1 Longlife 5W-30
SRS VIVA 1 alpha LS 5W-40 C3
SRS Special F Eco 5W-20
SRS Getriebefluid 5 L 75W-90 API GL-4+
SRS Wiolin ATF VI
SRS Viva 1 SLV Top 5W-30 отработка на BMW 1 Series F20 после 7 648 км
SRS ViVA 1 synth racing 5W-50 отработка на Nissan GT-R после 5000км
SRS Cargolub TLS PLUS 5W-30 отработка на IVECO двиг CURSOR 13 после 18000км
SRS Ecosynth 0W-40 отработка на Infiniti EX35 после 8500км
SRS VIVA 1 topsynth SAE 5W40 API SN отработка на Citroen Berlingo NEW B9 после 7000км
SRS VIVA1 Longlife 5W30 отработка на Citroen Berlingo после 5000 км
SRS Viva1 SLV Plus 5w-30 отработка Audi Q7 2015 4M после 7500км
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A4 после 6011 км
SRS VIVA 1 Topsynth Plus 5W-40 отработка на Citroen Berlingo после 5000 км.
SRS ViVA 1 ecosynth 0w-40 отработка на Kia cerato Koup после 9500км.
SRS ViVA 1 Topsynth Alpha LA 5W-30 отработка Audi A5 3.2 TFSI после 5000 км
SRS ViVA 1 special F eco 5w-20 отработка на Kia cerato Koup после 7900км
Кому интересно, сегодня отправил образцы свежего и отработки SRS VIVA1 topsynth SAE 5W40.Ждем разультаты.
второй год заливаю SRS VIVA 1 SPECIAL MS 5w30. не смотря на то, что оно разрабатывалось для немецких двигателей, я лью его в тойоту приус. Меняю раз год примерно через 10-15 тыс. Двигло масло не ест.
Из минусов: Когда коробка в положении "P" или "N" двигатель работает шумновато. Грешу на масло, но возможно это связано со спецификой приуса(Двигатель все время работает под нагрузкой, заряжая высоковольтную батарею.)
Иногда в морозы -20, -25, на холодную, бензиновый двигатель, после включения, начинает ацки тарахтеть, греметь и машина глохнет. При повторном заводе - все нормально. Может ли на плохую работу повлиять это масло?
З.Ы.К стати если нужна отработка, обращайтесь (сейчас пробег масла ок. 5000).
Изменено пользователем Алехандро
@Алехандро,заливал я это масло,двигатель работает очень мягко,на пентосе пожеще было.Насчет тарахтит на холодную и при повторной заводке нормально-это скорее всего пропуски зажигания в одном или двух цилиндрах(у меня такое было,заменили катушку),масло здесь ни причем.Если хотите,посылайте отработку в лабу,можно оплатить совместно,заинтересованные люди есть.
Изменено пользователем kep
@Алехандро,все здесь http://www.oil-club.ru/forum/topic/6773-skidivaemsja-na-analizi-masel-v-laboratorii/
@ModeratorSigma,его можно понять,просто еще не в курсе атмосферы форума,привыкнет.
Форма литровой канистры как у оригинала ВАГ 5-30 и МВ. Похоже они делают для них масла;
Изменено пользователем Azav
Начал тестировать SRS Viva 1 Topsynth Alpha LA 5w-30 на Тахе, после 1000 км, полет нормальный, из замеченного снижение расхода топлива до 17,3л/100 км с 20л и четкая реакция на педаль в пол
Такая форма литрушки у VAG LL2, а у LL3 другая. VAG вроде делает кастрол. MB раньше делал Fuchs, теперь также castrol делает оригинал. SRS на завод MB масло возит.
ого это после какого масла?
Сегодня утром -30С,ночью -33С.Машина завелась легко.Залито SRS VIVA1 topsynth SAE 5W40.
А у меня сегодня -26 и с SRS Viva 1 Topsynth Alpha LA 5w-30
машина завелась хорошо, посмотрел остатки масла в литровой банке, похоже на кисель, но еще еле-еле течет- при встряхивании не хлюпает
Изменено пользователем prokuratore
Прошел 7000 км, полет отличный, расход остался таким же.Никаких сторонних звкуков, двигатель жепчет (хоть молибдена там нет), цвет масла- рабочий темно-коричневый.Надо же никогда бы не подумал, что на недорогом SRS может быть очень приличный результат
