Масла Eurol ОБЩАЯ
Izb
Масла Eurol
Генеральный сайт: http://www.eurol.com/en/oil_products/product_advisor/2
Адрес завода: Energiestraat 12 7442 DA Nijverdal
Панорамные фотографии завода:
Вид на завод со спутника
Видео:
E1000764L - EUROL FLUENCE DXS 5W-30 4L
E1000761L - EUROL FLUENCE DXS 5W-30 1L
E1000691L - Eurol Fluence FE 5W-30 1L
E1000695L - Eurol Fluence FE 5W-30 5L
E10006960L - Eurol Fluence FE 5W-30 60L
E100069210L - Eurol Fluence FE 5W-30 210L
E1000621L - EUROL SYNTENCE 5W-30 1L
E1000624L - EUROL SYNTENCE 5W-30 4L
E1000625L - EUROL SYNTENCE 5W-30 5L
E1000651L - EUROL FORTENCE 5W-30 1L
E1000655L - EUROL FORTENCE 5W-30 5L
V172085638 - EUROL SUPER LITE ARCTIC 5W-30 1L
E1000094L - EUROL SUPER LITE ARCTIC 5W-30  4L
E1000091L - Eurol Super Lite Arctic 5W-30 1L
E1000671L - EUROL SYNERGY 0W-30 1L
E1000675L - EUROL SYNERGY 0W-30 5L
E1000641L - EUROL SYNERGY 0W-40 1L
E1000645L - EUROL SYNERGY 0W-40 5L
E1000911L - EUROL SUPER LITE 5W-30 1L
E1000914L - EUROL SUPER LITE 5W-30 4L
E10009120L - EUROL SUPER LITE 5W-30 20L
E100091210L - EUROL SUPER LITE 5W-30 210L
E1000921L - EUROL SUPER LITE 5W-40 1L
E1000924L - EUROL SUPER LITE 5W-40 4L
E10009220L - EUROL SUPER LITE 5W-40 20L
E100092210L - EUROL SUPER LITE 5W-40 210L
E1000931L - EUROL SUPER LITE 5W-50 1L
E1000934L - EUROL SUPER LITE 5W-50 4L
E100093210L - EUROL SUPER LITE 5W-50 210L
E1000851L - EUROL TURBO DI 5W-40 1L
E1000854L - EUROL TURBO DI 5W-40 4L
E10008520L - EUROL TURBO DI 5W-40 20L
E1000611L - EUROL MAXENCE RC 10W-60 1L
E1000614L - EUROL MAXENCE RC 10W-60 4L
E1001281L - EUROL EVOLENCE 0W-20 1L
E1001285L - EUROL EVOLENCE 0W-20 5L
E1001311L - EUROL EVOLENCE 5W-30 1L
E1001315L - EUROL EVOLENCE 5W-30 5L
E1000511L - EUROL SYNTO-V 5W-30 1L
E1000514L - EUROL SYNTO-V 5W-30 4L
E1000941L - EUROL TURBOSYN 10W-40 1L
E1000944L - EUROL TURBOSYN 10W-40 4L
E10009420L - EUROL TURBOSYN 10W-40 20L
E100094210L - EUROL TURBOSYN 10W-40 210L
E1000391L - EUROL TURBOSYN 15W-50 1L
E1000394L - EUROL TURBOSYN 15W-50 4L
E100039210L - EUROL TURBOSYN 15W-50 210L
E1100761L - EUROL FULTRASYN 75W-90 GL3/4/5 (ESTER+PAO, -51°C)
E1100751L - EUROL TRANSYN 75W-90 GL 4/5 1L
E1100755L - EUROL TRANSYN 75W-90 GL 4/5 5L
E11007520L - EUROL TRANSYN 75W-90 GL 4/5 20L
E110075210L - EUROL TRANSYN 75W-90 GL 4/5 210L
E1106301L - EUROL HPG SAE 80W-90 GL5 1L
E1106305L - EUROL HPG SAE 80W-90 GL5 5L
E11063020L - EUROL HPG SAE 80W-90 GL5 5L 20L
E110630210L - EUROL HPG SAE 80W-90 GL5 210L
E1106051L - EUROL MPG EP SAE 80W-90 GL4 1L
E1106054L - EUROL MPG EP SAE 80W-90 GL4 4L
E11060520L - EUROL MPG EP SAE 80W-90 GL4 20L
E110605210L - EUROL MPG EP SAE 80W-90 GL4 210L
E1136611L - EUROL ATF 1100 1L
E1136571L - EUROL ATF 6100 1L
E1136531L - EUROL ATF 6700 1L
E1136535L - EUROL ATF 6700 5L
E11365320L - EUROL ATF 6700 20L
E1136581L - EUROL ATF 7100 1L
E1136591L - EUROL ATF III F 1L
E1136595L - EUROL ATF III F 5L
E11365920L - EUROL ATF III F 20L
E1136501L - EUROL ATF II D 1L
E1136504L - EUROL ATF II D 4L
E11365020L - EUROL ATF II D 20L
E113650210L - EUROL ATF II D 210L
E1136631L - EUROL CVT 1304 1L
E801400500ML - EUROL BRAKEFLUID DOT 4 0.5L
E8014001L - EUROL BRAKEFLUID DOT 4 1L
E901304400G - EUROL BLUE STAR GREASE EP 2 0.4kg
E90130415KG - EUROL BLUE STAR GREASE EP 2 15kg
E901030400G - EUROL UNIVERSAL LITHIUM GREASE EP 2 0.4kg
E90103020KG - EUROL UNIVERSAL LITHIUM GREASE EP 2 20kg
E901070400G - EUROL MOLYBDENUM DISULPHIDE MOS2 GREASE 0.4kg
E90107020KG - EUROL MOLYBDENUM DISULPHIDE MOS2 GREASE 20kg
E90101020KG - EUROL LITHIUM GREASE EP 00 - 20kg
E5041451L - EUROL COOLANT GLX -36°C 1L
E5041455L - EUROL COOLANT GLX -36°C 5L
E50414520L - EUROL COOLANT GLX -36°C 20L
E504145210L - EUROL COOLANT GLX -36°C 210L
E5041051L - EUROL COOLANT BS -36°C 1L
E5041055L - EUROL COOLANT BS -36°C 5L
E50410520L - EUROL COOLANT BS -36°C 20L
E504105210L - EUROL COOLANT BS -36°C 210L
E5031521L - EUROL ANTIFREEZE GLX concentrate 1L
E5031525L - EUROL ANTIFREEZE GLX concentrate 5L
E50315220L - EUROL ANTIFREEZE GLX concentrate 20L
E50315260L - EUROL ANTIFREEZE GLX concentrate 60L
E503152210L - EUROL ANTIFREEZE GLX concentrate 210L
E5041051L - EUROL ANTIFREEZE BS 6580 concentrate 1L
E5041055L - EUROL ANTIFREEZE BS 6580 concentrate 5L
E50410520L - EUROL ANTIFREEZE BS 6580 concentrate 20L
E50315060L - EUROL ANTIFREEZE BS 6580 concentrate 60L
E504105210L - EUROL ANTIFREEZE BS 6580 concentrate 210L
E116001250ML - EUROL AIRCO OIL PAG 46 250ml
E116002250ML - EUROL AIRCO OIL PAG 100 250ml
E701445500ML - EUROL SUPER BRAKE CLEANER SPRAY (cпрей обезжириватель) 500ml
E701310400ML - EUROL CHAIN SPRAY PTFE (спрей-смазка для цепей) 400ml
E701300400ML - EUROL PENETRATING OIL SPRAY (разблокирующий спрей-смазка) 400ml
E701320400ML - EUROL SILICONE SPRAY (силиконовый спрей-смазка) 400ml
E401701250ML - EUROL RADIATOR SEALER (присадка для остановки течи радиатора) 250ml
E701420400ML - EUROL WHITE GREASE SPRAY with PTFE (спрей смазка на литиевой основе) 400ml
E601440600ML - EUROL HANDCLEANER WHITESTAR (мыло для рук) 600ml
E60144045L - EUROL HANDCLEANER WHITESTAR (мыло для рук) 4.5L
E1000701L - EUROL SPORTBIKE 10W-40 FULLSY (синтетическое) 1L
E1000971L - EUROL MOTORCYCLE 10W-40 (полусинтетическое) 1L
E1000974L - EUROL MOTORCYCLE 10W-40 (полусинтетическое) 4L
E1000111L - EUROL SPORT TOURING 10W-40 (минеральное) 1L
E1284331L - EUROL SUPER 2T FORMAX (синтетическое) 1L
E1284281L - EUROL TTX PROSCOOT (полусинтетическое) 1L
E1284001L - EUROL SX SPORT TWO STROKE (минеральное) 1L
E125400600ML - EUROL LAWN MOWER OIL SAE 30 (газонокосилки) 600ml
E1254001L - - EUROL LAWN MOWER OIL SAE 30 (газонокосилки) 1L
E1254501L - EUROL CHAINSAW OIL AK (масло для цепей) 1L
E1001441L - EUROL NAUTIC LINE 10W40 FCW 1L
E1284301L - EUROL NAUTIC LINE SUPER 2T OUTBOARD TCW-III 1L
E10871020L - EUROL HYKROL HLP ISO-VG 32 20L
E108710210L - EUROL HYKROL HLP ISO-VG 32 210L
E10880020L - EUROL HYKROL VHLP ISO-VG 32 20L
E108800210L - EUROL HYKROL VHLP ISO-VG 32 210L
E10881020L - EUROL HYKROL VHLP ISO-VG 46 20L
E108810210L - EUROL HYKROL VHLP ISO-VG 46 210L
E10011320L - EUROL FUSION 10W-40 20L
E100113210L - EUROL FUSION 10W-40 210L
EUROL артикульные коды.xlsx
Eurol Evolence 0W-20 Dexos1 (Gen2) (анализ июль 2019)
Eurol Syndura 5W-40 API SN
Eurol Syntence 5W-30
Eurol Maxence RC 10W-60
Eurol Super Lite 5W-40
Eurol Turbo DI 5W-40
Eurol Fluence DXS 5W-30
Eurol Turbosyn 10W-40
Eurol Synergy 0W-40
Eurol Synergy 0W-30
Eurol Super Lite 5W-30
Eurol Evolence 5W-30 API SN
Eurol Evolence 0W-20 API SN
Eurol Fortence 5W-30
Eurol Transfluid STF
Eurol ATF 6700
Eurol MTF FE 75W-85
Eurol MTF FE 75W-85 API GL-5 NEW 2023
Eurol Fultrasyn 75W-90
Eurol Evolence 5W-30 API SP отработка на Kia Rio 3 после 4914 км
Eurol Fortence 5W-30 отработка на Land Rover Freelander 2 после 6500км
Eurol Super Lite Arctic 5W-30 отработка на Nissan Qashqai после 7500км
Eurol Fortence 5W-30 отработка на Kia Ceed после 7200км
Eurol Super Lite 5W-40 отработка на Infifnity QX56 после 9800км.
Eurol Super Lite 5w40 отработка на Mitsubishi Pajero Sport после 6000 км.
Eurol Super Lite 5W-30 отработка на Mitsubishi Pajero после 7200 км.
Eurol Super Lite 5W30 отработка на Skoda Yeti после 5981 км.
Eurol Fluence DXS 5W-30 на Skoda Yeti после 5297 км.
Eurol Synergy 0W-30 отработка на Mitsubishi Lancer X после 6500 км.
Eurol Syntence 5W-30 отработка на Skoda Yeti после 4855км
Eurol Super Lite 5W-40 отработка на VW Bora после 8419 км.
Eurol Super Lite 5W-50 отработка на Renault Duster после 5084 км.
Eurol Super Lite 5W-30 отработка на Renault Logan после 8000 км.
Eurol Super Lite 5W-30 отработка на VW Touareg после 12900 км.
Eurol Super Lite Arctic 5W-30 + NGN Nord 5W-30 отработка на Toyota Landcruiser Prado после 7500 км.
Eurol Fortence 5W-30 отработка на Mitsubishi Pajero 4 после 7500 км.
Eurol Synergy 0W-40 отработка на Lada Kalina после 8000 км.
Eurol Super Lite Arctic 5W-30 отработка на Nissan Almera New после 13680 км.
Eurol Turbo DI 5-40 отработка на Nissan Pathfinder после 9653км - 241м.ч.
Eurol Evolence 0W-20 + присадка Eurol Engine Oil Treat на Hyundai Creta после 6350 км
Отчеты форумчан по маслам Eurol:
Eurol Syntence 5W30
Eurol Synergy 0w-40
Eurol Super Lite Arctic 5w-30
Eurol Super Lite Arctic 5W-30/NGN Nord 5W-30 на Toyota Prado 1GR-FE 4.0
Eurol Synergy 0w-30
NGN-Eurol,
Добрый день !
в теме ответов на вопросы, Вы сказали что Eurol Syndura ждать не стоит потому что дублирование будет.
а дублирование счем ?
я на сегодня не вижу в линейке еврола масло гряк, с допуском 229.5 и вязкостью 0 или 5w40.
из похожего Еврол Синерджи, Но это ПАО + КРЯК. Да и цена у него просто космос. Нечего плохого на еврол не скажу, общий пробег на авто 90ткм. НО. КОГДА ЕВРОЛ стоит 3000р а шелл хеликс ультра 2350р, как то не правильно.
поэтому я и спросил про синдуру, она и допускам новым отвечает и ценна должна быть конкурентная.
Изменено пользователем oil_find
Это правда, что Eurol и Хадо с 2004 г совместное предприятие ? Спрашиваю просто, для личного знания  :)
Ну всюду же пишут, и на сайте ХАДО в том числе - "В 2004 году, совместно с европейским производителем масел Eurol B.V., в Нидерландах было создано предприятие XADO Lube B.V., по производству масел XADO Atomic Oil с атомарным ревитализантом."
Да и ты ведь где-то прочитал, иначе откуда узнал?
А вот достоверно ли сие? наверное, да... но существует ли это "предприятие XADO Lube B.V." по сей день? хз... если XADO Atomic Oil выпускаются - возможно... я линейку их продуктов не знаю, никогда не интересовался - из всего смотрел только присадки в КПП
Товарищи в ассортименте новинка EUROL MTF 75W-85 FE GL-5 (полностью синтетическое: Эстеры и ПАО) - одно из лучших масел в своем классе!
Доступно для заказа по всей России (Экзист, Эмекс и прочие интернет площадки), а так же в фирменном магазине Eurol-shop
Экспертиза данного масла и описание ЗДЕСЬ
а есть такое же Тойота T-IV?
В ближайшие недели ассортимент еще пополниться следующими моторными маслами:
Eurol Syndura 5w40 (MB 229.5)
Eurol Ultrance VA 0w30 (Volvo VCC 95200377)
Eurol наладил выпуск нового продукта: Eurol Syntence LV 0W-20 соответствует VW 508.00 / 509.00 и имеет официальное одобрение VAG
В обозримом будущем данное масло пополнит российский ассортимент.
Изменено пользователем NGN-Eurol
Использую еврол на 3х машинах в семье, японце немце и корейце. Сумарно тысяч 100 накатали. Всё гуд. Вот интересно что за база у них? у кого покупают? Шелл? мобил? Ашланд?
Вообщем перевожу квадрики на Еврол http://www.eurol-shop.ru/component/jshopping/masla-dlya-2kh-i-4kh-taktnye-dvigateli/eurol-sportbike-10w-40-fullsy?Itemid=0 в мотор и в трансмиссию http://www.eurol-shop.ru/component/jshopping/transmissionnoe-maslo/eurol-mtf-75w-85-fe-gl-5?Itemid=0 , перед заливкой прогнал ТНК 10-40 минут 15,  за лето как минимум 1 раз меняю, готов 2-ую отработку анализировать, хотя что ему там будет за 1000км и 70моточасов. МАгазину спасибо за оперативность и очень удобную и гибкую доставку. По мере наезда буду отписываться тут и тут http://forum.atvclub.ru/index.php?threads/70948/page-53 . Спасибо за внимание)))
Доброго вечера!
Друзья подскажите, где в Тюмени возможно приобрести продукцию фирмы Eurol ? Может torcon в курсе? Спасибо.
если надо в наличии, то спросите в магазине specialoil (2гис в помощь) я как то видел у них продукцию NGN по сути тоже самое что еврол.
а так, я заказывал в емексе, на eurol-rus при просмотре каталогов есть даже ссылки для перехода в емекс\автодок\екзист.
Эльдар,
А какая информация по моей канистре без пластикового носика?
Удалось что-нибудь узнать?
А кто- что скажет про Eurol Actence 5w-30? Масло C3 /C4. RN720.
Взял на Renault 3.0dci - почернело! за 800км после капиталки.
В Украине нет ни Artic ни Nord 5w-30. Хотелось бы попробовать.
Спасибо
Изменено пользователем SurgRom
Взял на Renault 3.0dci - почернело! за 800км после капиталки..
Почернело или потемнело, критерии оценки индивидуальны
И после капиталки двигателя - вполне может быть такое
