Масла Eurol ОБЩАЯ
Izb
Масла Eurol
Генеральный сайт: http://www.eurol.com/en/oil_products/product_advisor/2
Адрес завода: Energiestraat 12 7442 DA Nijverdal
Панорамные фотографии завода:
Вид на завод со спутника
Видео:
E1000764L - EUROL FLUENCE DXS 5W-30 4L
E1000761L - EUROL FLUENCE DXS 5W-30 1L
E1000691L - Eurol Fluence FE 5W-30 1L
E1000695L - Eurol Fluence FE 5W-30 5L
E10006960L - Eurol Fluence FE 5W-30 60L
E100069210L - Eurol Fluence FE 5W-30 210L
E1000621L - EUROL SYNTENCE 5W-30 1L
E1000624L - EUROL SYNTENCE 5W-30 4L
E1000625L - EUROL SYNTENCE 5W-30 5L
E1000651L - EUROL FORTENCE 5W-30 1L
E1000655L - EUROL FORTENCE 5W-30 5L
V172085638 - EUROL SUPER LITE ARCTIC 5W-30 1L
E1000094L - EUROL SUPER LITE ARCTIC 5W-30  4L
E1000091L - Eurol Super Lite Arctic 5W-30 1L
E1000671L - EUROL SYNERGY 0W-30 1L
E1000675L - EUROL SYNERGY 0W-30 5L
E1000641L - EUROL SYNERGY 0W-40 1L
E1000645L - EUROL SYNERGY 0W-40 5L
E1000911L - EUROL SUPER LITE 5W-30 1L
E1000914L - EUROL SUPER LITE 5W-30 4L
E10009120L - EUROL SUPER LITE 5W-30 20L
E100091210L - EUROL SUPER LITE 5W-30 210L
E1000921L - EUROL SUPER LITE 5W-40 1L
E1000924L - EUROL SUPER LITE 5W-40 4L
E10009220L - EUROL SUPER LITE 5W-40 20L
E100092210L - EUROL SUPER LITE 5W-40 210L
E1000931L - EUROL SUPER LITE 5W-50 1L
E1000934L - EUROL SUPER LITE 5W-50 4L
E100093210L - EUROL SUPER LITE 5W-50 210L
E1000851L - EUROL TURBO DI 5W-40 1L
E1000854L - EUROL TURBO DI 5W-40 4L
E10008520L - EUROL TURBO DI 5W-40 20L
E1000611L - EUROL MAXENCE RC 10W-60 1L
E1000614L - EUROL MAXENCE RC 10W-60 4L
E1001281L - EUROL EVOLENCE 0W-20 1L
E1001285L - EUROL EVOLENCE 0W-20 5L
E1001311L - EUROL EVOLENCE 5W-30 1L
E1001315L - EUROL EVOLENCE 5W-30 5L
E1000511L - EUROL SYNTO-V 5W-30 1L
E1000514L - EUROL SYNTO-V 5W-30 4L
E1000941L - EUROL TURBOSYN 10W-40 1L
E1000944L - EUROL TURBOSYN 10W-40 4L
E10009420L - EUROL TURBOSYN 10W-40 20L
E100094210L - EUROL TURBOSYN 10W-40 210L
E1000391L - EUROL TURBOSYN 15W-50 1L
E1000394L - EUROL TURBOSYN 15W-50 4L
E100039210L - EUROL TURBOSYN 15W-50 210L
E1100761L - EUROL FULTRASYN 75W-90 GL3/4/5 (ESTER+PAO, -51°C)
E1100751L - EUROL TRANSYN 75W-90 GL 4/5 1L
E1100755L - EUROL TRANSYN 75W-90 GL 4/5 5L
E11007520L - EUROL TRANSYN 75W-90 GL 4/5 20L
E110075210L - EUROL TRANSYN 75W-90 GL 4/5 210L
E1106301L - EUROL HPG SAE 80W-90 GL5 1L
E1106305L - EUROL HPG SAE 80W-90 GL5 5L
E11063020L - EUROL HPG SAE 80W-90 GL5 5L 20L
E110630210L - EUROL HPG SAE 80W-90 GL5 210L
E1106051L - EUROL MPG EP SAE 80W-90 GL4 1L
E1106054L - EUROL MPG EP SAE 80W-90 GL4 4L
E11060520L - EUROL MPG EP SAE 80W-90 GL4 20L
E110605210L - EUROL MPG EP SAE 80W-90 GL4 210L
E1136611L - EUROL ATF 1100 1L
E1136571L - EUROL ATF 6100 1L
E1136531L - EUROL ATF 6700 1L
E1136535L - EUROL ATF 6700 5L
E11365320L - EUROL ATF 6700 20L
E1136581L - EUROL ATF 7100 1L
E1136591L - EUROL ATF III F 1L
E1136595L - EUROL ATF III F 5L
E11365920L - EUROL ATF III F 20L
E1136501L - EUROL ATF II D 1L
E1136504L - EUROL ATF II D 4L
E11365020L - EUROL ATF II D 20L
E113650210L - EUROL ATF II D 210L
E1136631L - EUROL CVT 1304 1L
E801400500ML - EUROL BRAKEFLUID DOT 4 0.5L
E8014001L - EUROL BRAKEFLUID DOT 4 1L
E901304400G - EUROL BLUE STAR GREASE EP 2 0.4kg
E90130415KG - EUROL BLUE STAR GREASE EP 2 15kg
E901030400G - EUROL UNIVERSAL LITHIUM GREASE EP 2 0.4kg
E90103020KG - EUROL UNIVERSAL LITHIUM GREASE EP 2 20kg
E901070400G - EUROL MOLYBDENUM DISULPHIDE MOS2 GREASE 0.4kg
E90107020KG - EUROL MOLYBDENUM DISULPHIDE MOS2 GREASE 20kg
E90101020KG - EUROL LITHIUM GREASE EP 00 - 20kg
E5041451L - EUROL COOLANT GLX -36°C 1L
E5041455L - EUROL COOLANT GLX -36°C 5L
E50414520L - EUROL COOLANT GLX -36°C 20L
E504145210L - EUROL COOLANT GLX -36°C 210L
E5041051L - EUROL COOLANT BS -36°C 1L
E5041055L - EUROL COOLANT BS -36°C 5L
E50410520L - EUROL COOLANT BS -36°C 20L
E504105210L - EUROL COOLANT BS -36°C 210L
E5031521L - EUROL ANTIFREEZE GLX concentrate 1L
E5031525L - EUROL ANTIFREEZE GLX concentrate 5L
E50315220L - EUROL ANTIFREEZE GLX concentrate 20L
E50315260L - EUROL ANTIFREEZE GLX concentrate 60L
E503152210L - EUROL ANTIFREEZE GLX concentrate 210L
E5041051L - EUROL ANTIFREEZE BS 6580 concentrate 1L
E5041055L - EUROL ANTIFREEZE BS 6580 concentrate 5L
E50410520L - EUROL ANTIFREEZE BS 6580 concentrate 20L
E50315060L - EUROL ANTIFREEZE BS 6580 concentrate 60L
E504105210L - EUROL ANTIFREEZE BS 6580 concentrate 210L
E116001250ML - EUROL AIRCO OIL PAG 46 250ml
E116002250ML - EUROL AIRCO OIL PAG 100 250ml
E701445500ML - EUROL SUPER BRAKE CLEANER SPRAY (cпрей обезжириватель) 500ml
E701310400ML - EUROL CHAIN SPRAY PTFE (спрей-смазка для цепей) 400ml
E701300400ML - EUROL PENETRATING OIL SPRAY (разблокирующий спрей-смазка) 400ml
E701320400ML - EUROL SILICONE SPRAY (силиконовый спрей-смазка) 400ml
E401701250ML - EUROL RADIATOR SEALER (присадка для остановки течи радиатора) 250ml
E701420400ML - EUROL WHITE GREASE SPRAY with PTFE (спрей смазка на литиевой основе) 400ml
E601440600ML - EUROL HANDCLEANER WHITESTAR (мыло для рук) 600ml
E60144045L - EUROL HANDCLEANER WHITESTAR (мыло для рук) 4.5L
E1000701L - EUROL SPORTBIKE 10W-40 FULLSY (синтетическое) 1L
E1000971L - EUROL MOTORCYCLE 10W-40 (полусинтетическое) 1L
E1000974L - EUROL MOTORCYCLE 10W-40 (полусинтетическое) 4L
E1000111L - EUROL SPORT TOURING 10W-40 (минеральное) 1L
E1284331L - EUROL SUPER 2T FORMAX (синтетическое) 1L
E1284281L - EUROL TTX PROSCOOT (полусинтетическое) 1L
E1284001L - EUROL SX SPORT TWO STROKE (минеральное) 1L
E125400600ML - EUROL LAWN MOWER OIL SAE 30 (газонокосилки) 600ml
E1254001L - - EUROL LAWN MOWER OIL SAE 30 (газонокосилки) 1L
E1254501L - EUROL CHAINSAW OIL AK (масло для цепей) 1L
E1001441L - EUROL NAUTIC LINE 10W40 FCW 1L
E1284301L - EUROL NAUTIC LINE SUPER 2T OUTBOARD TCW-III 1L
E10871020L - EUROL HYKROL HLP ISO-VG 32 20L
E108710210L - EUROL HYKROL HLP ISO-VG 32 210L
E10880020L - EUROL HYKROL VHLP ISO-VG 32 20L
E108800210L - EUROL HYKROL VHLP ISO-VG 32 210L
E10881020L - EUROL HYKROL VHLP ISO-VG 46 20L
E108810210L - EUROL HYKROL VHLP ISO-VG 46 210L
E10011320L - EUROL FUSION 10W-40 20L
E100113210L - EUROL FUSION 10W-40 210L
EUROL артикульные коды.xlsx
Eurol Evolence 0W-20 Dexos1 (Gen2) (анализ июль 2019)
Eurol Syndura 5W-40 API SN
Eurol Syntence 5W-30
Eurol Maxence RC 10W-60
Eurol Super Lite 5W-40
Eurol Turbo DI 5W-40
Eurol Fluence DXS 5W-30
Eurol Turbosyn 10W-40
Eurol Synergy 0W-40
Eurol Synergy 0W-30
Eurol Super Lite 5W-30
Eurol Evolence 5W-30 API SN
Eurol Evolence 0W-20 API SN
Eurol Fortence 5W-30
Eurol Transfluid STF
Eurol ATF 6700
Eurol MTF FE 75W-85
Eurol MTF FE 75W-85 API GL-5 NEW 2023
Eurol Fultrasyn 75W-90
Eurol Evolence 5W-30 API SP отработка на Kia Rio 3 после 4914 км
Eurol Fortence 5W-30 отработка на Land Rover Freelander 2 после 6500км
Eurol Super Lite Arctic 5W-30 отработка на Nissan Qashqai после 7500км
Eurol Fortence 5W-30 отработка на Kia Ceed после 7200км
Eurol Super Lite 5W-40 отработка на Infifnity QX56 после 9800км.
Eurol Super Lite 5w40 отработка на Mitsubishi Pajero Sport после 6000 км.
Eurol Super Lite 5W-30 отработка на Mitsubishi Pajero после 7200 км.
Eurol Super Lite 5W30 отработка на Skoda Yeti после 5981 км.
Eurol Fluence DXS 5W-30 на Skoda Yeti после 5297 км.
Eurol Synergy 0W-30 отработка на Mitsubishi Lancer X после 6500 км.
Eurol Syntence 5W-30 отработка на Skoda Yeti после 4855км
Eurol Super Lite 5W-40 отработка на VW Bora после 8419 км.
Eurol Super Lite 5W-50 отработка на Renault Duster после 5084 км.
Eurol Super Lite 5W-30 отработка на Renault Logan после 8000 км.
Eurol Super Lite 5W-30 отработка на VW Touareg после 12900 км.
Eurol Super Lite Arctic 5W-30 + NGN Nord 5W-30 отработка на Toyota Landcruiser Prado после 7500 км.
Eurol Fortence 5W-30 отработка на Mitsubishi Pajero 4 после 7500 км.
Eurol Synergy 0W-40 отработка на Lada Kalina после 8000 км.
Eurol Super Lite Arctic 5W-30 отработка на Nissan Almera New после 13680 км.
Eurol Turbo DI 5-40 отработка на Nissan Pathfinder после 9653км - 241м.ч.
Eurol Evolence 0W-20 + присадка Eurol Engine Oil Treat на Hyundai Creta после 6350 км
Отчеты форумчан по маслам Eurol:
Eurol Syntence 5W30
Eurol Synergy 0w-40
Eurol Super Lite Arctic 5w-30
Eurol Super Lite Arctic 5W-30/NGN Nord 5W-30 на Toyota Prado 1GR-FE 4.0
Eurol Synergy 0w-30
А что на дизельных двигателях с прямым впрыском и турбиной, масла перестали чернеть уже? :)
Может сменили так? Не совсем полностью старое слили?
День добрый, хотел почитать про масло eurol motorcycle 10w-40 на западных форумах, и что самое удивительное ничего не нашел, кроме как редких продаж в "странных" интернет магазинах, и пару позиций на EbaY. Вот так вот, странно всё это...
Изменено пользователем vodyanov
@vodyanov, да вроде все нормально... :)
форум Голанских мотоциклистов где упоминается масло Eurol Motorcycle 10W-40
http://www.motor-forum.nl/forum/list_messages/320541/39/0/olieolie
http://www.motor-forum.nl/forum/list_messages/320541/33/0/olie
http://www.motor-forum.nl/forum/list_messages/375904/43/Het-MF-NTV650GT-RevereHawkBros-topic-deel-11-44.html
http://www.motor-forum.nl/forum/list_messages/374801/9/Honda-CBF-deel-5-10.html
http://www.motor-forum.nl/forum/list_messages/159876/68/Yamaha-T-max-500cc-ervaringen-svp--69.html
http://www.motor-forum.nl/forum/list_messages/111844//
http://www.motor-forum.nl/forum/list_messages/196482/25/XJFJ-600900-topic-26.html
http://www.motor-forum.nl/forum/list_messages/384987/Nieuwe-koppeling-slipt-1.html
http://www.motor-forum.nl/forum/list_messages/389087/18/Het-Supergrote-Action-Olie-Topic-Nr-4-123-ACTION--19.html
http://www.motor-forum.nl/forum/list_messages/45684/welke-olie-gsxr-600-1.html
это не все дальше просто не стал...
магазины в Нидерландах (не по всей европе)
http://www.motomoto.nl/mm/nl/eurol-olie/436-eurol-motorcycle-10w40-synthetic.html
http://www.oliehandel.nl/merken/eurol
http://www.mercuriustools.nl/gereedschap/product/motorolie-synthetisch-10w40-4-liter-eurol-motorcycle/
https://www.toolmania.nl/nl/eurol-eurol-motorcycle-10w-40-1-liter.html
https://www.marktplaats.nl/a/auto-diversen/gereedschap/a1075344159-eurol-motorcycle-10w-40-1-liter.html
https://www.hgparts.nl/product/eurol-motorcycle-10w-40-1l/
дальше не стал искать.
Но нужно сразу отметить, что бы вы чуда не ждали. В Европе рынок поделен по мега-брендам Mobil Shell BP итд. Небольшие масло-блендеры находятся в условиях жесткой конкуренции и занимают не большой процент рынка. То есть если вы в Нидерландах зайдете в какой нибудь маркет, скорее всего там увидите Esso Mobil BP Shell... Мелкие бренды встретить труднее.
Кстати Eurol в Нидерландах занимает третье место по объему продаж. Что для небольшого завода очень достойный результат.
@torcon,  Спасибо большое, обязательно почитаю сейчас. Как говорится обжегшись однажды (Eni i-ride moto 10w-40),  начинаешь на воду дуть.
Всем здравствуйте!
Вернусь к тебе масел Eurol E1000094L и NGN V172085337,не пинайте, но спрошу.
Это одинаковые по составу масла? По сути одно и то же?
Просто появились сомнения, но и цена конечно разнится...
Можно подробнее чем ЕНИ не устроило?
Может не правильно подобрали или эксплуатировали?
Масло ЕНИ очень достойное
Всем здравствуйте!
Добрый день.
NGN NORD 5W-30 V172085337 и EUROL SUPER LITE ARCTIC 5W-30 E1000094L два абсолютно одинаковых продукта, с идентичным составом и характеристиками.
Хотя разница в цене действительно существенная - это связано с разными объёмами закупки за заводе Eurol (со стороны NGN и российского дистрибьютора Eurol): NGN  NORD продается на порядок больше.
В принципе нет никакого риска если я даже смешаю их перед заливкой, остались остатки еврола в канистре?
Верно, данные масла можно смешивать в любых пропорциях. Этот один и тот же продукт, в двух разных упаковках.
Мне кажется должно темнеть!!! Постепенно до 2000км. А у меня ПОЧЕРНЕЛО уже на 800км. Масло залито первое после капиталки, на сухой картер.
На сайте много пишут про бренд Eurol/Ngn. В Украине выбор не велик. Мой выбор пал - есть допуски на Renault и C3/C4. Отзывов по нему нигде нет. Теперь задумываюсь верное ли я масло взял?? Может оно у Вас по другому называется? Хочеться верим авторитетным людям, которые много лет поддерживают такой замечательный и нужный сайт.
Спасибо
Спасибо
О каком масле идёт речь?
