Mann W712/75 (Opel, Daewoo, Chevrolet)
Nordman
Масляный фильтр Mann W712/75
Применяемость:
Opel Ascona C 1,6 (16N) , 1,6i (C16LZ), 1,6i (C16NZ), 1,6i (E16NZ), 1,6 (16SV), 1,6 (16SH), 1,8i (C18NE), 1,8i (18SE), 1,8i (18E), 1,8 (E18NV), 2,0i (20NE), 2,0i (C20NE), 2,0i (20SEH)
Opel Calibra A 2,0i (C20NE), 2,0i 16V (X20XEV), 2,0i Turbo 16V (C20LET), 2,5i 24V (C25XE), 2,5i 24V (X25XE)
Opel Vectra A 1,4 (14NV) , 1,6 (16SV), 1,6i (E16NZ), 1,6i (C16NZ), 1,6i (X16SZ)
Opel Frontera A 2,2i 16V (X22XE)
Opel Frontera B 2,2i 16V (X22SE) , 2,2i 16V (Y22SE)
Opel Sintra 2,2i 16V (X22XE)
Daewoo Lanos (KLAT) 1,5i (A15SMS), 1,6i 16V (A16DMS)
Daewoo Assol 1,5i (A15SMS), 1,6i 16V (A16DMS)
Daewoo Espero (KLEJ) 2,0i (C20LE), 2,0i (C20LZ)
Daewoo Leganza (KLAV) 1,8i D-Tec, 2,0i C20SEL D-Tec , 2,0i E-Tec
Daewoo Nubira / Wagon (KLAJ) 1,6i 16V (A16DMS), 1,8i D-Tec (KLAJ)
Daewoo Nexia 1,5i (G15MF), Prince 1,8i (C18LE), 2,0i (C20LE) Espero (KLEJ) 1,8i (C18LE) , Super Saloon 2,0i (C20LE)
Chevrolet Blazer Елабуга 2,2i (C22NE)
Chevrolet Blazer (S10) 2,2i G TBi
Opel Omega B / Caravan 2,0i (20SE), 2,0i (X20SE), 2,2i 16V (Y22XE) , 2,2i 16V (Z22XE), 2,0i 16V (X20XEV)
Opel Zafira 2,0i Turbo 16V (Z20LET)
Opel Astra F/ Cabrio / Caravan 1,4i 16V (X14XE) , 2,0i 16V (X20XEV)
Opel Astra G / купе / Caravan 1,4i 16V (X14XE) , 1,4i 16V (Z14XE), 1,6i 16V (Z16SE), 1,6i (X16SZR) (C16SEL), (X16XEL), 2,0i 16V (X20XEV), 2,0i Turbo 16V (Z20LET), 2,2i 16V (C22SEL)
Opel Kadett E / CC / Caravan1,8i (18E) , 1,8i (18SE) масляный фильтр Opel
Calibra A (включая полный привод) 2,0i (C20NE), 2,0i 16V (C20XE)
Opel Frontera A Sport 2,0i (X20SE)
Opel Vectra B / СС / Caravan 1,6i (X16SZR), 1,6i 16V (X16XEL) , 2,0i 16V (X20XEV) , 2,0i 16V (C20SEL), 2,2i 16V (C22SEL)
Opel Vectra A / Caravan 2,0i 16V (20XE) , 2,0i 16V (C20XE)
Chevrolet Aveo (T200) 1,4i 16V (F14D3)
Chevrolet Lacetti (J200) 1,4i 16V (F14D3) , 1,6i 16V (F16D3) , 1,8i 16V (T18SED)
Chevrolet Evanda (V200) 2,0i 16V
Daewoo Nexia (N100) 1,5i 16V (A15MF)
Opel Antara 2,4i 16V (Z24XE)
Chevrolet Captiva (C100) 2,4i 16V (Z24SED)
Экспертизы масляных фильтров:
Mann W712/75 Made in Germany
ну помните же мое недовольство по поводу того что Mann в свои некоторые фильтра для японцев, корейцев укладывает фильтрующий материал "промокашку" тонкий. Однако вскрывая Mann для немцев VW Opel я такого кроилова не увидел. Там толстый фильтрующий материал, армированный, синтетические волокна встречаются.
Так вот вверху что вы видите я считаю должен быть и у азиатов а не то что они туда укладывают. Политика компании похоже для белых одна, для негров другая. "Хотите дешево? Будет вам дешево!" :)
Полезная площадь фильтрующего материала: длинна 170см x ширина 4см = площадь 680см2 - для такого небольшого фильтра и при таком толстом фильтрующем материале это более чем внушительно.
Вывод: Фильтр на пятерку.
Как я понял этот фильтр Long Life  , сейчас  является альтернативой  снятому с производства  W 712/22
Вес 712/75 - 279 грамм
На корпусе фильтра сверху  есть защитный шрифт с датой производства, увидеть его возможно если   посветить ультрафиолетом.
Дело не в политике Mann и делении на белых/черных.
Mann и большинство других производителей делают фильтры, основываясь на тех. требованиях производителей автомобилей - большинство японцев и корейцев считают фильтры с такими параметрами достаточными для своих машин...
Кроме того, японцы и корейцы обычно не практикуют лонглайф интервалы, в отличии от европейцев...
А есть ли данные о том какой диаметр фильтруемых частиц ?  Что может этот фильтр ? Сделан хорошо, но это не главный показатель. Может он как решето ?
Купил фильтр по артикулу. Если я не нарвался на подделку, то их начали производить в Боснии и Герцеговине Made in BA. Качество заметно упростили по сравнению с Made in Germany. Для стран третьего мира. С двух сторон по периметру обильные следы герметика/клея. Уплотнительное кольцо из мягкой резины, но снимается без усилия. Никакой УФ-метки естественно нет. Коробка немного другой формы. Штрих-код немецкий 401...
22.02.2021 в 22:01, Дюпелёк сказал:
kunashak уф только на неметчине на Корее тоже нема
Предыдущий фильтр, выпущенный в мае 2020, метку имеет. А сентябрьский уже из Боснии и Герцеговины.
На днях прошёл ТО в профильной СТО по замене масел с их расходниками. Покрутил в руках фильтр - сделан в Германии. УФ метка есть. Страна производства зависит от партии, видимо.
Также купил этот фильтр made in BA.
Заглянул в него эндоскопом и сравнил с германским. Фото прилагаю.
220916_190615_GERM.thumb.jpg.c57581d7cd09c654372e02468a6073c9.jpg220916_190250_BA.thumb.jpg.bea7ed711623c0971695ecaa0e04b280.jpg
Обратите внимание на немецком заклепки, а боснийском - нет и заусенцев больше. Подделка?
Изменено пользователем lion26
Нет, оригинал. Это их отличия (немецких и боснийских), о чем писалось неоднократно.
Изменено пользователем Andrey_74
