Масла Febi
Масло Febi
32941 - Febi Engine Oil Longlife 5W-30 1L
32947 - Febi Engine Oil Longlife Plus 5W-30 5L
32921 - Febi 20W-50 1L
32922 - Febi 20W-50 5L
32923 - Febi 20W-50 25L
32924 - Febi 20W-50 60L
38408 - Febi 20W-50 200L
32925 - Febi 15W-40 1L
32926 - Febi 15W-40 4L
32927 - Febi 15W-40 5L
32928 - Febi 15W-40 25L
32929 - Febi 15W-40 60L
32930 - Febi 15W-40 200L
32931 - Febi     10W-40    1
32932 - Febi     10W-40    4
32933 - Febi     10W-40    5
32934 - Febi     10W-40    60
32935 - Febi     10W-40    200
32936 - Febi     5W-40    1
32937 - Febi     5W-40    4
32938 - Febi     5W-40    5
32939 - Febi     5W-40    60
32940 - Febi     5W-40    200
32941 - Febi     5W-30 Longlife    1
32942 - Febi     5W-30 Longlife    4
32943 - Febi     5W-30 Longlife    5
32944 - Febi     5W-30 Longlife    60
39336 - Febi     5W-30 Longlife    200
32945 - Febi     5W-30 Longlife Plus    1
32946 - Febi     5W-30 Longlife Plus    4
32947 - Febi     5W-30 Longlife Plus    5
32948 - Febi     5W-30 Longlife Plus    60
39337 - Febi     5W-30 Longlife Plus    200
34052 - Febi     10W-40 Truck Longlife Plus    200
48416 - Febi     5W-30 Longlife EU6    205
101140 - Febi     0W-40    1
101141 - Febi     0W-40    4
101142 - Febi     0W-40    5
101143 - Febi     0W-40    60
101144 - Febi     0W-40    200
105840 - Febi     10W-40 Truck Special Longlife    5
34047 - Febi     10W-40 Truck Special Longlife    20
34048 - Febi     10W-40 Truck Special Longlife    60
34049 - Febi     10W-40 Truck Special Longlife    200
101150 - Febi     5W-30 HC-FO    1
101151 - Febi     5W-30 HC-FO    4
101152 - Febi     5W-30 HC-FO    5
101153 - Febi     5W-30 HC-FO    60
101154 - Febi     5W-30 HC-FO    200
108350 - Febi     5W-20 HC E-FO    1
108351 - Febi     5W-20 HC E-FO    4
108352 - Febi     5W-20 HC E-FO    5
108360 - Febi     5W-30 HC C4    1
108361 - Febi     5W-30 HC C4    4
108362 - Febi     5W-30 HC C4    5
Febi Long Life Plus 5W-30 API SN
Febi SAE 5W-30 Longlife
Febi SAE 10W-40 Truck Special Longlife
Febi SAE 0W-40
Febi SAE 5W-40
Febi Longlife Plus 5W-30
Febi Long Life HC-FO 5W-30
Febi 39070
Febi Zentralhydraulikol
Лабораторные анализы - Отработки - UOA
FEBI Longlife Plus 5W-30 отработка на VW Touareg после 13 000км
FEBI Longlife Plus 5W-30 отработка на VW Touareg после 9006км
Febi Loglife Plus 5W-30 отработка на Volkswagen Touareg после 8700км
Febi Long Life HC-FO 5W-30 отработка на TOYOTA VERSO  после 8000 км
Febi SAE 0W-40 отработка на Skoda Yeti после 6760км
@apex75, сможешь чем то подкрепить свои слова?
Ничем, кроме 11 летнего опыта использования жиж Феби на авто, многих из них F-класса. Схожесть канистр оригинала МБ и SRS и Febi трудно объяснить, коли форма канистры SRS таки уникальная, и они льют на своём заводе масло для МБ. Насчёт перекрытия допусков МБ - это из материалов Фэби. Я им почему-то верю. Случаев косяков с химией не припоминаю. Скачайте буклет по жижам, там есть все допуски.
...Насчёт перекрытия допусков МБ - это из материалов Фэби. Я им почему-то верю. Случаев косяков с химией не припоминаю. Скачайте буклет по жижам, там есть все допуски.
И тем не менее ни в одном бюллетене  MB Mehrbereichsmotoröle Spezifikation 229.1/229.3/229.5/229.51 нет и не было моторных масел Febi.
Как тут говорили и не единожды, многих хороших масел нет на BEVO. Вы как себе представляете, находится в Германии и незаконно присваивать себе допуски или одобрения ? Бильштайн это Вам не шарашка. Ещё раз повторю - скачайте каталог с сайта и ищите нужные Вам допуски . Перечисленные есть
http://www.amazon.co.uk/dp/B006DHYDHU/?tag=leprice053-21&SubscriptionId=AKIAJU65XXVJAEFAZH3Q
Видимо Биль не считает нужным заносить сотни тысяч  за листинг, а заказывает правильные масла, которые у SRS имеют всё необходимое.
Изменено пользователем apex75
Как тут говорили и не единожды, многих хороших масел нет на BEVO. Вы как себе представляете, находится в Германии и незаконно присваивать себе допуски или одобрения ? ...Ещё раз повторю - скачайте каталог с сайта и ищите нужные Вам допуски ...
Как здесь уже заявлялось не единожды: есть допуск и есть соответствие; допуск даёт автопроизводитель, о соответствии заявляет блендер.
Ещё раз повторяю - если в бюллетене MB упоминания о масле Febi нет, а в фирменном каталоге Febi есть ссылка на допуск MB, стало быть речь идёт о соответствии допуску, но не о наличии допуска.
Что не понятно?
Ес
Что не понятно?
Ес
Вас кто-то заставляет масло Фэби насильно в мотор лить ? Не ну нравится - не покупайте, в чём сложность ?
А это уже другая тема, не имеющая к допуску MB ровным счётом ни какого отношения.
Что же касается интереса к моторному маслу Febi, то пока нет результатов его анализа, нет к нему и практического интереса.
Вам виднее.
Жидкости Фэби поставляются на конвеер Мерседеса
Где можно ознакомиться с этой неожиданной информацией? Не байками "знатоков" с лавочки, а официальной.
Вам виднее.
Как раз наоборот; не вижу информации о заводе на котором Febi якобы мешает и разливает своё моторное масло, а если всё же фасует не своё, то не вижу инфы чьё это масло.
Про  TUV слышали ? Мне этого предостаточно.
Про TUV естественно слышал и да же частенько работал с их сертификатами.
Если моторные масла Febi упомянуты в каком либо сертификате TUV, то будьте так любезны, покажите его скан.
Надеюсь не нужно объяснять, что сертификат выдан не только на сайлент-блоки и аммортизаторы ?
Ваши объяснения совершенно не нужны, потому что в этом сертификате, выданном Ferdinand Bilstein GmbH + CO.KG в 1994 г., чёрным по белому указана область его действия, а именно (цитирую дословно) - "Разработка, изготовление и продажа запчастей и прецизионных, обработанных на токарном станке деталей для автомобилей."
Так что моторные масла, если они и разливаются по канистрам под эгидой Febi ни коим образом не касаются выложенного вами скана сертификата TUV.
Кстати, если вы действительно являетесь почитателем моторных масел Febi, то почему не выложите в тему сканы этикеток и маркировок канистр или скан российского сертификата соответствия на эти масла?
И анализы свежих и отработок - вообще то, что надо. Можно будет разговаривать предметно и тематически.
