Масла Febi
Масло Febi
32941 - Febi Engine Oil Longlife 5W-30 1L
32947 - Febi Engine Oil Longlife Plus 5W-30 5L
32921 - Febi 20W-50 1L
32922 - Febi 20W-50 5L
32923 - Febi 20W-50 25L
32924 - Febi 20W-50 60L
38408 - Febi 20W-50 200L
32925 - Febi 15W-40 1L
32926 - Febi 15W-40 4L
32927 - Febi 15W-40 5L
32928 - Febi 15W-40 25L
32929 - Febi 15W-40 60L
32930 - Febi 15W-40 200L
32931 - Febi     10W-40    1
32932 - Febi     10W-40    4
32933 - Febi     10W-40    5
32934 - Febi     10W-40    60
32935 - Febi     10W-40    200
32936 - Febi     5W-40    1
32937 - Febi     5W-40    4
32938 - Febi     5W-40    5
32939 - Febi     5W-40    60
32940 - Febi     5W-40    200
32941 - Febi     5W-30 Longlife    1
32942 - Febi     5W-30 Longlife    4
32943 - Febi     5W-30 Longlife    5
32944 - Febi     5W-30 Longlife    60
39336 - Febi     5W-30 Longlife    200
32945 - Febi     5W-30 Longlife Plus    1
32946 - Febi     5W-30 Longlife Plus    4
32947 - Febi     5W-30 Longlife Plus    5
32948 - Febi     5W-30 Longlife Plus    60
39337 - Febi     5W-30 Longlife Plus    200
34052 - Febi     10W-40 Truck Longlife Plus    200
48416 - Febi     5W-30 Longlife EU6    205
101140 - Febi     0W-40    1
101141 - Febi     0W-40    4
101142 - Febi     0W-40    5
101143 - Febi     0W-40    60
101144 - Febi     0W-40    200
105840 - Febi     10W-40 Truck Special Longlife    5
34047 - Febi     10W-40 Truck Special Longlife    20
34048 - Febi     10W-40 Truck Special Longlife    60
34049 - Febi     10W-40 Truck Special Longlife    200
101150 - Febi     5W-30 HC-FO    1
101151 - Febi     5W-30 HC-FO    4
101152 - Febi     5W-30 HC-FO    5
101153 - Febi     5W-30 HC-FO    60
101154 - Febi     5W-30 HC-FO    200
108350 - Febi     5W-20 HC E-FO    1
108351 - Febi     5W-20 HC E-FO    4
108352 - Febi     5W-20 HC E-FO    5
108360 - Febi     5W-30 HC C4    1
108361 - Febi     5W-30 HC C4    4
108362 - Febi     5W-30 HC C4    5
Febi Long Life Plus 5W-30 API SN
Febi SAE 5W-30 Longlife
Febi SAE 10W-40 Truck Special Longlife
Febi SAE 0W-40
Febi SAE 5W-40
Febi Longlife Plus 5W-30
Febi Long Life HC-FO 5W-30
Febi 39070
Febi Zentralhydraulikol
Лабораторные анализы - Отработки - UOA
FEBI Longlife Plus 5W-30 отработка на VW Touareg после 13 000км
FEBI Longlife Plus 5W-30 отработка на VW Touareg после 9006км
Febi Loglife Plus 5W-30 отработка на Volkswagen Touareg после 8700км
Febi Long Life HC-FO 5W-30 отработка на TOYOTA VERSO  после 8000 км
Febi SAE 0W-40 отработка на Skoda Yeti после 6760км
Канистры всем им и еще многим немецким брендам поставляет Mauser
На дне канистра маркировка либо Mauser либо буква М
Изменено пользователем PRADA21
8 минут назад, Rowe Russland сказал:
 как и антифризы,
И HEPU тоже?
Изменено пользователем TDream
В 07.12.2017 в 15:17, PRADA21 сказал:
От того что они закупают у ROWE, не означает что рецептура не меняется.
Как правило производителя загоняют в определенный бюджет...
Достаточно просто заглянуть в MSDS, чтобы убедиться в этом
Добрый день, Читаю про масло Febi.
Если льют на Rowe, и пишут допуски соответствующие маслу Rowe (в частности VW), можно ли с полной уверенностью говорить. что допуски соответствуют?
Ну т.е. допуск получало масло определенной рецептуры. Следовательно можно говорить, что оригинальное масло Rowe предположительно лучше масла Febi на дополнительный пакет присадок только улучшающее масло получившее допуск. Так ли это? Или это тоже масло, и дело лишь в маркетинге? Поправьте, если что не так в моих рассуждениях?
В 20 мая 2018 в 10:44, КонстантинЗ сказал:
Это просто маркетинг ( желание продать свою же продукцию пусть и под другими брендами) :- в Германии много очень качественных брендов (в разных отраслях - от профессионального инструмента,  TV  и другой бытовой техники до масел и спецжидкостей) - местный житель их и так хорошо знает / покупает…! Уровень же производства их выше потребностей своего рынка (они развиваются наращивая производство) - вот они охотно и продают свою продукцию маркам , давно самостоятельно торгующим  за пределами страны (Febi в частности - ) …
Простой пример: - внутренности электроинструмента (  к примеру  электрофен)   марок Bosch,  AEG , Metabo  совсем не их а именитой древней фирмы Shteinel  - Но тот же фен под своей маркой стоит дешевле оных …!!! Просто очень мало кто об этом знает…  Вы покупаете  "раскрученный" Bosch - а немец с большим удоволствием предпочтет марку  Kress или Metabo (узкоспециализированный производитель качественного инструмента) ...
Прошу извенить за примеры "не по теме"...
Изменено пользователем Vino
Немецкий рынок - отдельная тема... Локальные марки достаточно широко представлены. Но и они во всю пользуют сборочные возможности других стран.
Ну так просвятите поподробнее пожалуйста. Ведь именно про это изначально и был вопрос....
22 часа назад, КонстантинЗ сказал:
Резюмируя.
Покупаю Febi - подразумеваю ROWE. Качество точно не теряю????
Откройте ради интереса Exist ( если ему доверяете ) и посмотрите какие сопоставимые аналоги он предлагает оригинальному маслу VAG…  (Febi там есть практически всегда  - "3 звезды") Это немецкое масло для немецких же коробок…  Список тот не велик...
28.04.2018 в 11:35, Rowe Russland сказал:
Да, масла FEBI делает ROWE на своём заводе в Вормсе, антифризы FEBI, и ещё под десятком других марок, разливает в Бубенхайме.
А почему именно ROWE? Упаковка FEBI один в один как у продукции SRS.
Все купленные мной запчасти Febi, хорошо ходят. Не самые дешёвые, но всегда лучше чем неизвестно что. Масла ещё не пробовал.
Даже на их сайте идёт один и тот же товар, но под именами Febi, Swag, Blue Print.
Изменено пользователем Messenger
да, подтверждаю..... они даже оригинал иногда перепаковывают.... покупал колесные болты феби на зафиру, маркировка на них была GM.
И так...залил FEBI Long Life HC-FO 5W-30 в ВОЛЬВО S40, двигатель B5244S4.
авто 2007г. выпуска для американского рынка. с космическим пробегом, но бодрая лошадка.
замену делал без промывки.
до отметки МАКС. ушло 6,2л.
изменений в работе двигателя не заметил. работает как обычно ,гидрики не стучат. проверить по холоду не представилось возможным,но по жаре в пробках-норм.
в настоящий момент пробег на этом масле 10т.км. уровень на минимуме, без доливки.
пы.сы. покупал по случаю.однако цена-качество без конкурентов.ИМХО
Изменено пользователем Giga
Очень странно;Почему догадываются, что разливает ROWE, а канистры точно такие же как у SRS?
Изменено пользователем Восход
такие канистры производит фирма Mauser для многих производителей масла, не только для Febi и SRS, так что это не показатель истинного производителя масла.
Изменено пользователем madis
