Сложные эфиры в синтетических смазках. Вопросы к TomNJ
TomNJ Hello. there are so-called refrigeration oils. They work in compressors of refrigeration units. POE the question is - do these oils contain any additives? Or is it a pure base oil?
  11.04.2020 в 15:10, bratok1981 сказал:
Yes and yes.  Some refrigeration oils are just pure POEs, and some contain additives.  Those that do contain additives usually have very small amounts, mostly anti-oxidants and corrosion inhibitors, and sometimes some anti-wear.
POEs entered the refrigeration market after the Montreal Protocol in 1987 because the old CFC refrigerants had to change to HFC chemistry due to the effect of the CFC gases on the ozone layer.  The old mineral oil lubricants used with the old CFCs were not miscible with the new HFC refrigerants, and so esters and PAGs entered the market as new lubricants for the new refrigerants.  Along with system design modifications, this was a lot of change for the compressor manufacturers and it worried them, especially since their products were expected to remain in service for decades.  In the past, field failures cost them a lot of money.  Most of the old mineral oils did not contain additives, and so some compressor manufacturers did not want to introduce yet another change and wanted only esters with no additives.  Others accepted additives but wanted to minimize them.
TomNJ oil FUCHS RENISO TRITON are you familiar with this oil?
BITZER  BECOOL SUNISO SL Do these oils have EP additives? Can POE be used to improve engine oil properties? 5-10% Polar properties for example.
Изменено пользователем bratok1981
TomNJ Greetings! Is there any benefit from adding POE to engine oil? Purpose: to clean the engine of deposits, including rings.
У меня плохой английский, а гугл переводчик переведет с русского неправильно. Кто понимает? Спросите Тома.
"Том, на протяжении многих лет, мы замечаем по анализам отработанных масел UOA, что эстеры в масле способствуют быстрому падению щелочного числа TBN. Нежели чем у масел без эстеров. Это правда? Почему это происходит? Ведь современные эстеры в маслах, имеют нулевое (или почти нуль) кислотное число TAN"
  11.04.2020 в 19:20, TomNJ сказал:
Another way to do this is to add a quart of Redline oil which they claim has a high POE content.  At least this is safe and would not dilute the additives in your oil.
In Redline oil, it is POE, and not other esters? You could give a description, a formula?
  11.04.2020 в 19:38, TomNJ сказал:
If you have a gas chromatogram of a Redline oil I should be able to see the ester and perhaps identify it.
Hmm ... I definitely don't. Can you comment on this?
This is oil RedLine Professional-Series 5W-20
