Сложные эфиры в синтетических смазках. Вопросы к TomNJ
  14.04.2020 в 15:14, Poziom1989 сказал:
@ Tomnj You know some technologies that increase polarity in oil based on PAO , besides ester, AN etc.
Diesters, polyol esters, and ANs are the primary ones used in motor oils.  Ketjenlube polymer esters can also be used but are expensive.
  14.04.2020 в 21:38, TomNJ сказал:
I generally do not mix oils of different brands because I do not have to, but if I needed to do so I would without fear so long as they are approved oils.
  14.04.2020 в 20:34, SAE20 сказал:
How do you feel about mixing motor oils ?
Dear Gentlemen! Could you please come to an agreement and a common opinion?:)
We, ordinary people, would not like to mix oils with trembling hands:Rulezz_alcoman2:
@TomnjThank you for your response. You think that you can completely dispense with esters and use e.g.
https://www.aftonchemical.com/SBU/Lubricant-Components/SealSwellAdditives/HiTEC-082
The aniline point is important from what I know.
What do you think about OSP technology, DOW produces them.
TomNJ
What do you think of anti-friction oil additives?
For instance .
Add tungsten additive to redline oil (there is a lot of molybdenum)?
It is believed that tungsten complements molybdenum well.
  15.04.2020 в 06:36, Poziom1989 сказал:
@ Tomnj Thank you for your response. You think that you can completely dispense with esters and use eg
Seal swell additives work if all you want is seal swell. Polar base oils also help with additive solubility and can improve volatility and lubricity to some degree. Aniline point is one measure of polarity.  I have no experience with the OSP technology.
Изменено пользователем TomNJ
  15.04.2020 в 10:58, Alex сказал:
Tomnj
Friction modifiers are mainly to enhance fuel efficiency.  I have no experience with Tungsten additives.
TomNJ Какой срок хранения у моторных масел с ораническими модификаторами трения, может ли он быть меньше, чем у масла без OFM. Какие OFM применяются в грузовых дизельных маслах?
Изменено пользователем ss333
  16.04.2020 в 13:26, TomNJ сказал:
Dodatki do pęcznienia fok działają, jeśli wszystko czego potrzebujesz to pęcznienie fok. Polarne oleje bazowe również pomagają w dodatkowej rozpuszczalności i mogą w pewnym stopniu poprawić lotność i smarowność. Punkt anilinowy jest jedną z miar polarności.  Nie mam doświadczenia z technologią OSP.
If you look at this oil, there are no esters, An etc.
  16.04.2020 в 13:56, ss333 сказал:
TomNJ  What is the shelf life for motor oils with oranic friction modifiers, can it be shorter than for oils without OFM. Which OFMs are used in truck diesel oils?
I doubt they affect shelf life if not stored at high temperatures.  I do not know what is used in diesel oils.
  16.04.2020 в 15:19, Poziom1989 сказал:
I do not know what is in this oil for seals or solubility.  Could have Ketjenlube or small dose of aromatic ester. :unknown:
TomNJ большое спасибо за ваши ответы! :)
Вопрос: POE могут clean отложения (sludge) в двигателе? Esters обладают моющими свойствами?
Среди нас ходят слухи, что масла c содержанием POE хорошо моют двигатель. Но я не встречал документальных подтверждений этому, только слухи.
torcon так TomNJ уже отвечал. Да, эстеры моют, а самое главное - эффективно поддерживают чистоту:
  12.04.2020 в 17:43, TomNJ сказал:
If I was formulating an oil for my car I would add a proper POE at 20-30% in order to obtain the cleaning, volatility, and lubricity effects
  18.04.2020 в 07:07, СИНТЭКС сказал:
 Поддерживать чистоту легче, чем отмывать грязь. Вопрос в концентрации. В ветке про ПОЭ говорят о 2-3-5%. TomNJ о 20-30%.
