Lukoil Avantgarde Ultra 5W-40 (API CI-4/SL, ACEA E7, ОАО «Автодизель» «ЯМЗ»)
torcon
Lukoil Avantgarde Ultra 5W-40 API CI-4 API SL
Lukoil Avantgarde Ultra 5W-40 photo1.JPGLukoil Avantgarde Ultra 5W-40 photo2.JPG
Lukoil Avangard Ultra 5W-40.pdf
Спецификации:  API CI-4/SL, ACEA E7, ПАО «Автодизель» (ЯМЗ), VOLVO VDS-3, Renault VI RLD-2, Cummins CES 20078, MB 228.3, Deutz DQC III-18, ПАО «КАМАЗ», Mack EO-N, MAN M 3275-1, MTU Oil Category 2, Caterpillar ECF-2/1-a, JASO DH-1
Техническая документация:
tds_474_l_rus_lukoil_avantgarde_ultra_5w-40_26.01.2023.pdfПолучение информации...
  TDS_AVANGARD_ULTRA_2005_rus_v1.2_05.08.2015.pdfПолучение информации...
http://www.lukoil-masla.ru/products/commerce/motoroils/00057/
19511 - Lukoil Avantgarde Ultra 5w40 API CI-4 API SL 5L
1595288 - Lukoil Avantgarde Ultra 5w40 API CI-4 API SL 5L
1559623 - Lukoil Avantgarde Ultra 5w40 API CI-4 API SL 18L
1595286 - Lukoil Avantgarde Ultra 5w40 API CI-4 API SL 18L
3052069 - Lukoil Avantgarde Ultra 5w40 API CI-4 API SL 21,4L
19513 - Lukoil Avantgarde Ultra 5w40 API CI-4 API SL 50L
1595287 - Lukoil Avantgarde Ultra 5w40 API CI-4 API SL 50L
3037288 - Lukoil Avantgarde Ultra 5w40 API CI-4 API SL 216,5L
Лукойл Авангард Ультра 5W-40
Lukoil Avantgarde Ultra 5W-40 отработка на Toyota Land Cruiser 100 diesel после 9.350км
Лукойл Авангард Ультра 5W-40 API CI-4 API SL на Toyota Curren после 6000км
Sorry i misunderstood you a little Dimmy..
"Badsykes, I think that advanced API diesel classes (CH-4, CI-4) speak for themselves. Don't forget such oils are different from common SM/CF or SN/CF. Besides, the diesel class goes first. If you prefer better heavy duty protection Lukoil Avantgarde Professional is for you."
From this line i understood to stay away from Avantgarde Ultra because is more for diesel and not for my gasoline.So after this i looked at the others Truck oils and i felt the same so i ruled them out.
To be clear YES i do seek heavy duty engine oil..Now you made it clear that except the Profesional i can use the Avantgarde Ultra..
I want also to replace Gearbox oil and Transfer Box oil..In the Car book it says that both of them (gear and transfer boxes) need the same oil like the engine..Can i use Avantgarde Ultra here too or i need something else?
Изменено пользователем badsykes
To sum it up you may use Avantgarde Ultra in both types engines and Professional only in Diesels.
As for the Gear box - use transmission oils of GL4 level or GL4/GL5. About 10 years ago motor oils were used because transmission oils were few but the latter are better.
In other places including the other box pour GL5.
  10.07.2013 в 15:14, torcon сказал:
@toureech, ты прямо попал на форум я смотрю и глаза разбежались :D "А правда я могу залить то" "А правда я могу залить это?". :) В этой теме обсуждается анализ масла, не его применимость. Есть темы в разделе Лукойл. Есть раздел "Посоветуйте масло новичка сюда!" А ты везде оффтопишь :) Прекращай. (Конечно можешь залить и спокойно ездить он для зимы в -30 подходит отлично)
Я уже читал этот форум и именно на нем выбрал себе масло Лукойл Люкс Синтетическое 5W-40 API SN.
На форум я пришел для выбора правильного интервала замены масла, чтобы не загрязнять ДВС.
Еще одна причина мало тупого флуда.
Для себя пришел к выводу, что паленого масла нет, есть плохой бензин и несвоевременная замена масла.
Но г-н Dmitriy67 меня смутил. Он зимой заливает в ДВС 0w-40(а живем мы в одном городе). Вот в процессе подбора доступного масла наткнулся на хорошую альтернативу. Правда это анализы только канистры из одной партии.
"3) Температура застывания -46 - здравствуй Сибирь!
4) Вспышка 220 - не плохо
5) Вязкость имитации холодной прокрутки ССS при -30 - 4700 - Сибиряк!"
Единственное, что смущает - это отсутствие у Лукойл Авангард Ультра 5W-40 допуска API SL, ACEA A3/B4. Я правильно понимаю, что это означает что в процессе производства рецептура может меняться(ее же никто не контролирует?)
Но в любом случае, если вы подскажете номер партии масла, то возможно я смогу купить на 2-3 года именно того самого сибирского масла...
А какому маслу соответствует этот допуск? скриншот EOLCS Licensee Directory
Изменено пользователем toureech
Официально SL есть только у минералки 15-40. Но по составу Ультра 5-40 лучше, так что при такой зольности оно наи подходит и является хорошей альтернативой Люксу SN. Но по зимним свойствам они одинаковые. Главное не t застывания, а CCS.
  11.07.2013 в 12:16, badsykes сказал:
I want to thank Dimmy for advices.
You are always welcome in case of questions upon oils :)
I'm glad you look at Lukoil products being abroad. This brand is really up to the latest international requirements (API, ACEA, approvals).
Изменено пользователем Dimmy
Я вобще не пойму где вы их находите, сколько езжу в автомаги захожу, ни где не встречал.
да их продают в основном там где ты не ходишь. Оптовые базы где закупаются дальнобои. У нас тоже в магазинах нет, на оптовых базах где дальнобои покупают бочками и 20литровками - Авангарды присутсвуют.
Понравился мне Авангард, угарает умеренно - определенно меньше Lukoil Luxe 5W-40 (именно в моем двигателе). Движок работает не тихо конечно - как трактор и работает. Об остальном возможно позже. "Возможно" потому что есть вероятность что я не буду делать анализ отработки - не особо сейчас с деньгами.
Torcon, а к какому периоду ты его менять будешь, через месяц? Мне например интересно увидеть результаты в том числе и с твоей машины, я-бы закинул денег - в свою я точно чисто грузовое масло не залью, так хоть на твоей увижу в сравнении - лучше оно или хуже для легковушки. Только я не ранее чем через месяц смогу денег закинуть.
  Abc писал:
у них есть API SL так что границы давно стерты)
спасибо за предложение но я сам постараюсь...
Уважаемые форумчане, помогите определиться, какой из двух луков выбрать для своего авто.
Имею land cruiser 80 двигатель турбодизель 4,2 л (1hd-t). ТНВД механический, всяческих экологических приблуд в виде ЕГР, сажевых фильтров, катализаторов и проч нет.
Для себя ничего предосудительного в заливе лука не вижу, ибо ПНОС в родном городе, заправки с маслами с ПНОСа на каждом углу.
Морозы за -30у нас далеко не редкость.
Смотрел было в строну Люкс 5-40 SN, но тут пошла, эта тема про Авангард и я уже в смятении.
По образованию гуманитарий и потому мало что смыслю в показателях масел по результатам анализов, а времени самообучением заниматься нет.
Вообщем, какое из этих масел будет лучше для моего авто Люкс или Авангард, и если можно расскажите почему в общих понятных для гуманитария словах.
Спасибо.
@maka, авангард именно это ултра 5W40 считаю лучше, у него больше противоизносных чем у люкса. Минус перед люксом такой, у Авангарда моющий нейтрализующий пакет на основе кальция и магния - мы тестили Valvoline synpower 0W-40 на кальциево магниевом пакете и что то как то не очень подобные пакеты останавливают рост кислотного. Износа конечно не было и свой интервал масло отходило, но возможно люкс в этом плане со своим чисто кальциевым пакетом сильнее.
Идеальный вариант - льешь авангард, откатываешь интервал 5000км сливаешь и направляешь мне на анализ, а там уже все понятно будет. То что было у вэльволин не факт что будет у Авангарда.
  13.08.2013 в 05:10, torcon сказал:
Да, я внутренне и склонялся больше в сторону авангарда.
У меня соображения были такие, что раз я взял дизельку, то масло буду менять по весне и по осени.
А учитывая, что в мой двигатель его надо аж почти под 10л, то на раскрученных брендах не понятно какого розлива можно разориться.
А люкс бюджетно, авангард еще бюджетнее.
Не думаю, что от авангарда должно быть хуже моему коню, ибо мыслю, что двигатель у меня разработки начала 90-х, а уровень масел, вроде, как далеко ушел с тех времен.
Единственное, что все же как авангард будет в морозы. По тесту смотрю, вроде, супер. Однако сумятицу вносит некий озвученный здесь отрицательный "опыт".
Было бы дело под лето, наверно, залил бы авангард не думая.
