Масла Chevron
Масла Chevron
Официальный сайт: http://www.chevronlubricants.com/
Артикулы коды для заказа в инетмагазинах
Вариант № 1
223501482 - Chevron Havoline Motor Oil 0W-20 0,946L
076568796280 - Chevron Havoline Motor Oil 5W-20 0,946L
223393721 - Chevron Havoline Motor Oil 5W-20", 0.946L
223502482 - Chevron Havoline ProDS Full Synthetic 5W-20, 0.946L
223503482 - Havoline ProDS Full Synthetic 5W-30, 0.946L
223394485 - Chevron Havoline Motor Oil 5W-30, 4.73L
223394533 - Chevron Havoline Motor Oil 5W-30, 4.73L
076568796297 - Chevron Havoline Motor Oil 5W-30 0,946L
223726482 -  Chevron Havoline ProDS Full Synthetic 5W-40, 0.946L
223504482 - Chevron Havoline ProDS Euro Full Synthetic 5W-40, 0.946L
223395533 - Chevron Havoline Motor Oil 10W-30, 4.73L
223395481 - Chevron Havoline Motor Oil 10W-30, 0.946L
223396485 - Chevron Havoline Motor Oil 10W-40, 4.73L
223396481 - Chevron Havoline Motor Oil 10W-40, 0.946L
220135721 Chevron Supreme Motor Oil SAE 5W-20 946mL
220013533 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013553 Chevron Supreme Motor Oil SAE 5W-30 4,83L
220013429 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013719 Chevron Supreme Motor Oil SAE 5W-30 946mL
220155719 Chevron Supreme Motor Oil SAE 10W-30 946mL
220155533 Chevron Supreme Motor Oil SAE 10W-30 4,83L
220059533 Chevron Supreme Motor Oil SAE 10W-40 4,83L
220059429 Chevron Supreme Motor Oil SAE 10W-40 3,78L
220059719 Chevron Supreme Motor Oil SAE 10W-40 946mL
220060719 Chevron Supreme Motor Oil SAE 20W-50 946mL
220060533 Chevron Supreme Motor Oil SAE 20W-50 3,78L
257001388 - Chevron Delo 400 Syn XSP 5W-30 3,785 л
257001448 - Chevron Delo 400 Syn XSP 5W-30 18,9 л
257001981 - Chevron Delo 400 Syn XSP 5W-30 208 л
235195389 CHEVRON DELO 400 Synthetic SAE 0W-30 3,78L
271210339 CHEVRON DELO 400 LE Synthetic SAE 5W-30 3,78L
271210448 CHEVRON DELO 400 LE Synthetic SAE 5W-30 19L
271207448 CHEVRON DELO 400 LE Synthetic SAE 5W-40 19L
271207339 CHEVRON DELO 400 LE Synthetic SAE 5W-40 3,78L
222210339 CHEVRON DELO 400 LE 10W-30 3,78L
222210448 CHEVRON DELO 400 LE 10W-30 19L
222220721 CHEVRON DELO 400 LE 15W-40 946 mL
222220463 CHEVRON DELO 400 LE 15W-40 3,78L
222220478 CHEVRON DELO 400 LE 15W-40 9,946L
222220448 CHEVRON DELO 400 LE 15W-40 19L
224615463 CHEVRON DELO 400 SD SAE 15W-30 3,78L
224615448 CHEVRON DELO 400 SD SAE 15W-30 19L
235101448 CHEVRON DELO 400 Multigrade SAE 15W-40 19L
235101339 CHEVRON DELO 400 Multigrade SAE 15W-40 3,78L
235101721 CHEVRON DELO 400 Multigrade SAE 15W-40 946mL
271220722 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 946mL
271220448 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 19L
271220339 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 3,78L
Вариант №2
235101721           CHEVRON  DELO ® 400  15W-40 CI-4 plus       0.946л.
01020013           CHEVRON  DELO ® 400  15W-40 CI-4 plus       3.785л.
01020012           CHEVRON  DELO ® 400  15W-40 CI-4 plus      18.9л.
235101981           CHEVRON  DELO ® 400  15W-40 CI-4 plus      208л.
01020012           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      18.9л.
01020011           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      208л.
01020013           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus   3.785л.
235105339           CHEVRON  Delo®     400 MGX SAE 15W-40         3.785л.
235105428           CHEVRON  Delo®     400 MGX SAE 15W-40       18.9л.
235105981           CHEVRON  Delo®     400 MGX SAE 15W-40       208л.
8888880           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40     20л.
8888881           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40    208л.
271201448           CHEVRON URSA  SUPERPLUS  EC 15W-40    18.9л.
271201981           CHEVRON URSA  SUPERPLUS  EC 15W-40    208л.
222210448           DELO 400 LE 10W-30  18.9л.
222210981           DELO 400 LE 10W-30  208л.
222210339           DELO 400 LE 10W-30  3.785л.
01020048           DELO 400 LE 15W-40  0,946л.
222220448           DELO 400 LE 15W-40  18.9л.
222220981           DELO 400 LE 15W-40  208л.
222220463           DELO 400 LE 15W-40  3.785л.
271210448           DELO 400 LE SYNTHETIC 5W-30  18.9л.
271210981           DELO 400 LE SYNTHETIC 5W-30  208л.
271210339           DELO 400 LE SYNTHETIC 5W-30  3.785л.
271207448           DELO 400 LE SYNTHETIC 5W-40  18.9л.
271207981           DELO 400 LE SYNTHETIC 5W-40  208л.
271207339           DELO 400 LE SYNTHETIC 5W-40  3.785л.
235101721           DELO 400 MULTIGRADE 15W-40  0.946л.
235101448           DELO 400 MULTIGRADE 15W-40  18.9л.
235101981           DELO 400 MULTIGRADE 15W-40  208л.
235101339           DELO 400 MULTIGRADE 15W-40  3.785л.
01020051           DELO 400 SAE 10W  18.9л.
235109981           DELO 400 SAE 10W  208л.
01020051           DELO 400 SAE 40  18.9л.
235195351           DELO 400 SYNTHETIC 0W-30  0.946л.
235195448           DELO 400 SYNTHETIC 0W-30  18.9л.
235195981           DELO 400 SYNTHETIC 0W-30  208л.
235195389           DELO 400 SYNTHETIC 0W-30  3.785л.
01020047           DELO 400 XLE  Synblend 10W-30  18.9л.
01020007           DELO 400 XLE  Synblend 10W-30  208л.
01020048           DELO 400 XLE  Synblend 10W-30  3.785л.
254591542           CHEVRON BLACK PEARL GREASE  EP 2     397г
255659642           CHEVRON MOLY GREASE        EP NLGI 1     397г
01020290           CHEVRON MOLY GREASE        EP NLGI 1    182кг
255660642           CHEVRON MOLY GREASE        EP NLGI 2     397г
01020295           CHEVRON MOLY GREASE        EP NLGI 2    182кг
255660451           CHEVRON MOLY GREASE        EP NLGI 2   15.9кг
274509451           CHEVRON MULTIFAK                EP 00   15.9кг
01020303           CHEVRON MULTIFAK                EP 1     397г
01020302           CHEVRON MULTIFAK                EP 1   15.9кг
274503642           CHEVRON MULTIFAK                EP 2     397г
274503451           CHEVRON MULTIFAK                EP 2   15.9кг
01020218           CHEVRON RPM ARCTIC GREASE        EP NLGI 1    397г
01020218           CHEVRON RYKOTAC  GREASE        EP     397г
254504642           CHEVRON SRI GREASE        NLGI 2     397г
277111642           CHEVRON STARPLEX                EP 2     397г
250186642           CHEVRON ULTI-PLEX GREASE   EP NLGI 1     397г
250185642           CHEVRON ULTI-PLEX GREASE   EP NLGI 2     397г
250188642           CHEVRON ULTI-PLEX GREASE SYNT EP   1.5   397г
01020250           CHEVRON ULTRA-DUTY         EP NLGI 0     397г
238012642           CHEVRON ULTRA-DUTY         EP NLGI 1     397г
238011642           CHEVRON ULTRA-DUTY         EP NLGI 2     397г
235212451           DELO GREASE EP NLGI 00  15.9кг.
01020218           DELO GREASE EP NLGI 1  397г.
235208451           DELO GREASE EP NLGI 2  15.9кг.
235208642           DELO GREASE EP NLGI 2  397г.
01020218           DELO GREASE ESI  397г.
222206642           DELO HEAVY DUTY  EP 2  397г.
222231451           DELO HEAVY DUTY MOLY 3%  EP 2  15,9кг.
01020205           CHEVRON 2 CYCLE OIL             TC-W3     18,9л
01020204           CHEVRON 2 CYCLE OIL             TC-W3  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/20  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/30  0.946л
01020158           CHEVRON SUPREME 100% SYNTHETIC   5/40  0.946л
01020152           CHEVRON SUPREME 100% SYNTHETIC  10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL         5/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/40  0.946л
01020142           CHEVRON SUPREME MOTOR OIL          30  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/20  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/30  0.946л
01020102           CHEVRON SUPREME MOTOR OIL        5/30  3.785л
01020113           CHEVRON SUPREME MOTOR OIL       10/30  0.946л
01020111           CHEVRON SUPREME MOTOR OIL       10/30  208л.
01020112           CHEVRON SUPREME MOTOR OIL       10/30  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/30  4,73 л
01020123           CHEVRON SUPREME MOTOR OIL       10/40  0.946л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  4,73 л
01020133           CHEVRON SUPREME MOTOR OIL       20/50  0.946л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  3.785л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  4,73 л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O   5/30  0.946л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O 10/30  0.946л
SAIC-GM Full Synthetic 0W-20 Chevron-Tianjin Made in China
SAIC-GM Full Synthetic 5W-30 Chevron-Tianjin Made in China
Chevron Delo 400 Syn XSP 5W-30 API CK-4
Chevron Delo LE 400 5W-40
Chevron Delo LE 400 5W-30
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2
Лабораторные анализы - Отработки - UOAoil-club.ru
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2 отработка на Toyota Rav4 после 9460км
Chevron Delo 400LE Synthetic 5W-40 отработка на Dodge Ram 2500 после 8200 км.
Chevron Delo 400 XLE Synblend 10W-30 CJ-4 отработка на Ford Focus ST после 8000 км.
Chevron Delo 400 LE Synthetic 5W-40 отработка на Dodge Ram после 16790 км.
Спасибо, посмотрел, так и есть.
получается что в данном случае достаточно допуска SAE.
Купил 2 канистры 4л и 1л (в галлонах естественно) 10w40
Большая канистра с логотипом Шеврон рельефным и наклейка действительно как бы вплавлена. Американское масло. Наклейка наша беленькая на русском языке без указания импортера. С большой канистры отлипает легко и почти не оставляет следов. Обычная завинчив пробка без контр. вскрытия. Под ней фольгобумажка, которая огибается пополам(по толщине слой спец) и за ето можно потянуть и вскрыть канистру.Фольгобумажка прилеплена не очень, но держится. такое исполнение раньше не видел однако.
Мелкая канистра с рельефом наливаемого масла из бутылки. Наклейка обычная но приклеена хорошо. Есть значек для телефона о производителе. Пробка с контролем вскрытия и все. Треснула при вскрытии как-то не четко.
По запаху и виду масло одинаковое в обеих канистрах.
Изменено пользователем AliBaba
После долгих утомительных штудирований масло-форумов нашел таки искомое - Chevron Suprime 10w-40.
А иначе бессмысленно читать oil-club.ru, если не заливать одно из 3-х: Валволин, Равенол, Петро-Канада (Шеврон))))
@carmanager, и в чём смысл такого маневра? Уход с рецептуры под евро требования на более простую американскую?
@carmanager, и в чём смысл такого маневра?...
Да, Дмитрий, по стройным таблицам и цифрам в них все выходит замечательно. Но наблюдение работы двигателя рождает трепетные ощущения. На Shell HX7 10w-40 двигатель шумит и греется, выхлопная труба в саже. До Shell-а заливал только BP Visco 5w-40.
Пропало тихое, бархатное урчание. Почему не BP? Угар после 7000.
Перейдя на Chevron, ожидаю обресть тишину и стабильность уровня.
А какие у меня альтернативы? Чтоб мягко и надежно.
На минералке II группы крутить двигатель опасно? Какие варианты?
Изменено пользователем carmanager
@carmanager, доработать ГБЦ и поставить другой выпускной коллектор с доводкой прошивки.
Дмитрий, совет не профильный для Ойл-клуб.ру ))) Здесь ожидаешь получить рецепт целебной микстуры.
потому что цепочка размышлений строится инертно и в лоб, что касается вопросов вязкости. Калине и 5w-30 мало поможет без напильника. Надо-то рублей 20 для силового, 10-15 на трансмиссию и 8-10 на шумку своими руками. И нужная машина класса "надолго" в руках.
Это я так шел по пути устранения угара после BP 5w-40.
Не было там (в Visco) как выясняется того снижения уровня, о коем стоило бы волноваться.
Ну, так что? Рецепт на стол!
carmanager ты чего хочешь получить? самый простой и тупой вариант для калины вон кастрол едге 0w30 или 5w30 у них вязкость нижняя граница 40 и по износу всех делают...
и будет тижина....а лить в простой двигатель масло с заточкой на непонятно че...я вообще плохо понимаю под какие движки идут америкосовские масла с вязкостью 40..?
вон примеры есть митсу дизель 2.7 льет мобил 0ц40 ...ливанули оригинал 30 так он ваще тупить стал в чем секрет??
насчет форума осн масса здесь людей тусуется с рекомендуемой вязкостью 30 начиная от допотопных авто кончая новыми поэтому и уклон в Валволин, Равенол, Петро-Канада (Шеврон)....
Изменено пользователем westf2
Удалять сообщения - это в порядке вещей? Не по теме? Оскорбляю?
Получается, Дмитрию, как Спецу Ойл-клуба позволительно давать такие уничижительные определния:
"Калине и 5w-30 мало поможет без напильника"?
Запрещается:
1) Оскорбления, нецензурная брань, не литературные слова, негативные лозунги, в том числе по отношению к личности, национальности, расовой или религиозной, политической принадлежности другого человека. Любая критика должна быть аргументированной и сдержанной. Здесь не терпятся любые фашистские высказывания - будьте осторожнее в словах!
Что за мания у всех ныть после заслуженного наказания? Читайте правила! А не высказывайте свои недовольствия в теме по Chevron. Теперь это еще и оффтоп
5) Оффтоп: Старайтесь, чтобы Ваши сообщения соответствовали тематике Форума! Сообщения, не относящиеся к теме форума и размещенные с нарушением правил, удаляются или выделяются в отдельную тему - это оффтоп! Если созданная тема не соответствует тематике ветки, она переносится в другую ветку.
Народ, обнаружил у себя в городе в продаже Chevron delo 0w30 по цене 400 руб. за 0,946 литра. Посмотрел характеристики и офигел от индекса вязкости (190) и температуры застывания (-60). Я так понимаю, что в данном масле должен быть очень приличный процент ПАО?
Не подскажите как оно с точки зрения защиты от износа, просто я хочу приобрести масло 0W30 ACEA A3, а в этих американских классификациях чёта я запутался?
@kirber, бери беги и никому не рассказывай ;) Давно искал это масло но у нас его нет...
