Масла Chevron
Масла Chevron
Официальный сайт: http://www.chevronlubricants.com/
Артикулы коды для заказа в инетмагазинах
Вариант № 1
223501482 - Chevron Havoline Motor Oil 0W-20 0,946L
076568796280 - Chevron Havoline Motor Oil 5W-20 0,946L
223393721 - Chevron Havoline Motor Oil 5W-20", 0.946L
223502482 - Chevron Havoline ProDS Full Synthetic 5W-20, 0.946L
223503482 - Havoline ProDS Full Synthetic 5W-30, 0.946L
223394485 - Chevron Havoline Motor Oil 5W-30, 4.73L
223394533 - Chevron Havoline Motor Oil 5W-30, 4.73L
076568796297 - Chevron Havoline Motor Oil 5W-30 0,946L
223726482 -  Chevron Havoline ProDS Full Synthetic 5W-40, 0.946L
223504482 - Chevron Havoline ProDS Euro Full Synthetic 5W-40, 0.946L
223395533 - Chevron Havoline Motor Oil 10W-30, 4.73L
223395481 - Chevron Havoline Motor Oil 10W-30, 0.946L
223396485 - Chevron Havoline Motor Oil 10W-40, 4.73L
223396481 - Chevron Havoline Motor Oil 10W-40, 0.946L
220135721 Chevron Supreme Motor Oil SAE 5W-20 946mL
220013533 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013553 Chevron Supreme Motor Oil SAE 5W-30 4,83L
220013429 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013719 Chevron Supreme Motor Oil SAE 5W-30 946mL
220155719 Chevron Supreme Motor Oil SAE 10W-30 946mL
220155533 Chevron Supreme Motor Oil SAE 10W-30 4,83L
220059533 Chevron Supreme Motor Oil SAE 10W-40 4,83L
220059429 Chevron Supreme Motor Oil SAE 10W-40 3,78L
220059719 Chevron Supreme Motor Oil SAE 10W-40 946mL
220060719 Chevron Supreme Motor Oil SAE 20W-50 946mL
220060533 Chevron Supreme Motor Oil SAE 20W-50 3,78L
257001388 - Chevron Delo 400 Syn XSP 5W-30 3,785 л
257001448 - Chevron Delo 400 Syn XSP 5W-30 18,9 л
257001981 - Chevron Delo 400 Syn XSP 5W-30 208 л
235195389 CHEVRON DELO 400 Synthetic SAE 0W-30 3,78L
271210339 CHEVRON DELO 400 LE Synthetic SAE 5W-30 3,78L
271210448 CHEVRON DELO 400 LE Synthetic SAE 5W-30 19L
271207448 CHEVRON DELO 400 LE Synthetic SAE 5W-40 19L
271207339 CHEVRON DELO 400 LE Synthetic SAE 5W-40 3,78L
222210339 CHEVRON DELO 400 LE 10W-30 3,78L
222210448 CHEVRON DELO 400 LE 10W-30 19L
222220721 CHEVRON DELO 400 LE 15W-40 946 mL
222220463 CHEVRON DELO 400 LE 15W-40 3,78L
222220478 CHEVRON DELO 400 LE 15W-40 9,946L
222220448 CHEVRON DELO 400 LE 15W-40 19L
224615463 CHEVRON DELO 400 SD SAE 15W-30 3,78L
224615448 CHEVRON DELO 400 SD SAE 15W-30 19L
235101448 CHEVRON DELO 400 Multigrade SAE 15W-40 19L
235101339 CHEVRON DELO 400 Multigrade SAE 15W-40 3,78L
235101721 CHEVRON DELO 400 Multigrade SAE 15W-40 946mL
271220722 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 946mL
271220448 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 19L
271220339 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 3,78L
Вариант №2
235101721           CHEVRON  DELO ® 400  15W-40 CI-4 plus       0.946л.
01020013           CHEVRON  DELO ® 400  15W-40 CI-4 plus       3.785л.
01020012           CHEVRON  DELO ® 400  15W-40 CI-4 plus      18.9л.
235101981           CHEVRON  DELO ® 400  15W-40 CI-4 plus      208л.
01020012           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      18.9л.
01020011           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      208л.
01020013           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus   3.785л.
235105339           CHEVRON  Delo®     400 MGX SAE 15W-40         3.785л.
235105428           CHEVRON  Delo®     400 MGX SAE 15W-40       18.9л.
235105981           CHEVRON  Delo®     400 MGX SAE 15W-40       208л.
8888880           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40     20л.
8888881           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40    208л.
271201448           CHEVRON URSA  SUPERPLUS  EC 15W-40    18.9л.
271201981           CHEVRON URSA  SUPERPLUS  EC 15W-40    208л.
222210448           DELO 400 LE 10W-30  18.9л.
222210981           DELO 400 LE 10W-30  208л.
222210339           DELO 400 LE 10W-30  3.785л.
01020048           DELO 400 LE 15W-40  0,946л.
222220448           DELO 400 LE 15W-40  18.9л.
222220981           DELO 400 LE 15W-40  208л.
222220463           DELO 400 LE 15W-40  3.785л.
271210448           DELO 400 LE SYNTHETIC 5W-30  18.9л.
271210981           DELO 400 LE SYNTHETIC 5W-30  208л.
271210339           DELO 400 LE SYNTHETIC 5W-30  3.785л.
271207448           DELO 400 LE SYNTHETIC 5W-40  18.9л.
271207981           DELO 400 LE SYNTHETIC 5W-40  208л.
271207339           DELO 400 LE SYNTHETIC 5W-40  3.785л.
235101721           DELO 400 MULTIGRADE 15W-40  0.946л.
235101448           DELO 400 MULTIGRADE 15W-40  18.9л.
235101981           DELO 400 MULTIGRADE 15W-40  208л.
235101339           DELO 400 MULTIGRADE 15W-40  3.785л.
01020051           DELO 400 SAE 10W  18.9л.
235109981           DELO 400 SAE 10W  208л.
01020051           DELO 400 SAE 40  18.9л.
235195351           DELO 400 SYNTHETIC 0W-30  0.946л.
235195448           DELO 400 SYNTHETIC 0W-30  18.9л.
235195981           DELO 400 SYNTHETIC 0W-30  208л.
235195389           DELO 400 SYNTHETIC 0W-30  3.785л.
01020047           DELO 400 XLE  Synblend 10W-30  18.9л.
01020007           DELO 400 XLE  Synblend 10W-30  208л.
01020048           DELO 400 XLE  Synblend 10W-30  3.785л.
254591542           CHEVRON BLACK PEARL GREASE  EP 2     397г
255659642           CHEVRON MOLY GREASE        EP NLGI 1     397г
01020290           CHEVRON MOLY GREASE        EP NLGI 1    182кг
255660642           CHEVRON MOLY GREASE        EP NLGI 2     397г
01020295           CHEVRON MOLY GREASE        EP NLGI 2    182кг
255660451           CHEVRON MOLY GREASE        EP NLGI 2   15.9кг
274509451           CHEVRON MULTIFAK                EP 00   15.9кг
01020303           CHEVRON MULTIFAK                EP 1     397г
01020302           CHEVRON MULTIFAK                EP 1   15.9кг
274503642           CHEVRON MULTIFAK                EP 2     397г
274503451           CHEVRON MULTIFAK                EP 2   15.9кг
01020218           CHEVRON RPM ARCTIC GREASE        EP NLGI 1    397г
01020218           CHEVRON RYKOTAC  GREASE        EP     397г
254504642           CHEVRON SRI GREASE        NLGI 2     397г
277111642           CHEVRON STARPLEX                EP 2     397г
250186642           CHEVRON ULTI-PLEX GREASE   EP NLGI 1     397г
250185642           CHEVRON ULTI-PLEX GREASE   EP NLGI 2     397г
250188642           CHEVRON ULTI-PLEX GREASE SYNT EP   1.5   397г
01020250           CHEVRON ULTRA-DUTY         EP NLGI 0     397г
238012642           CHEVRON ULTRA-DUTY         EP NLGI 1     397г
238011642           CHEVRON ULTRA-DUTY         EP NLGI 2     397г
235212451           DELO GREASE EP NLGI 00  15.9кг.
01020218           DELO GREASE EP NLGI 1  397г.
235208451           DELO GREASE EP NLGI 2  15.9кг.
235208642           DELO GREASE EP NLGI 2  397г.
01020218           DELO GREASE ESI  397г.
222206642           DELO HEAVY DUTY  EP 2  397г.
222231451           DELO HEAVY DUTY MOLY 3%  EP 2  15,9кг.
01020205           CHEVRON 2 CYCLE OIL             TC-W3     18,9л
01020204           CHEVRON 2 CYCLE OIL             TC-W3  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/20  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/30  0.946л
01020158           CHEVRON SUPREME 100% SYNTHETIC   5/40  0.946л
01020152           CHEVRON SUPREME 100% SYNTHETIC  10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL         5/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/40  0.946л
01020142           CHEVRON SUPREME MOTOR OIL          30  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/20  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/30  0.946л
01020102           CHEVRON SUPREME MOTOR OIL        5/30  3.785л
01020113           CHEVRON SUPREME MOTOR OIL       10/30  0.946л
01020111           CHEVRON SUPREME MOTOR OIL       10/30  208л.
01020112           CHEVRON SUPREME MOTOR OIL       10/30  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/30  4,73 л
01020123           CHEVRON SUPREME MOTOR OIL       10/40  0.946л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  4,73 л
01020133           CHEVRON SUPREME MOTOR OIL       20/50  0.946л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  3.785л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  4,73 л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O   5/30  0.946л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O 10/30  0.946л
SAIC-GM Full Synthetic 0W-20 Chevron-Tianjin Made in China
SAIC-GM Full Synthetic 5W-30 Chevron-Tianjin Made in China
Chevron Delo 400 Syn XSP 5W-30 API CK-4
Chevron Delo LE 400 5W-40
Chevron Delo LE 400 5W-30
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2
Лабораторные анализы - Отработки - UOAoil-club.ru
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2 отработка на Toyota Rav4 после 9460км
Chevron Delo 400LE Synthetic 5W-40 отработка на Dodge Ram 2500 после 8200 км.
Chevron Delo 400 XLE Synblend 10W-30 CJ-4 отработка на Ford Focus ST после 8000 км.
Chevron Delo 400 LE Synthetic 5W-40 отработка на Dodge Ram после 16790 км.
Коля,
а что ты ориентируешься на легкомоторку - у тебя дизель, лей спокойно Delo 400 LE - градаций до дури 5/10/15W340, 5/10/W30
золы мало - 1 %, быстрее всего честный гидрокряк третьей группы 5W ISOSYN, полусинька 10W, 15W - минералка
Сами базовые масла здесь - http://www.chevronbaseoils.com/products/
вопросы по маслам - http://www.chevronbaseoils.com/faq.aspx
Вадим, в паджерика я лью идемитсу и всё окей тут вопросов не возникает. Дело 400 5w40 лежит в гараже два галлона, но его на зиму не буду, так как тесты Торкона не впечатляют по зиме, а так масло прекрасное спору нет. Идемитсу дороговато выходит на круглый год, но для зимы лучше для меня нет. Delo 400 0ц30 не рассматриваю так как тридцатку не люблю.
Помимо этого у жены и брата, что ни есть та самая легкомоторка. Есть доступ к оф диллеру Шеврона и ещё скидка на эту продукцию, вот поэтому и легкомоторка вызывает интерес.
За ссылки спасибо, но я так и не понял путаницы с характеристиками Хаволина.
Товарищи любители Шеврона давайте разбираться вместе, ибо я мозг сломал.
Суприм остаётся как был, тут всё понятно минералка второй группы.
Дело 400 видимо остаётся без изменений.
Хаволин Синтетик уже надо понимать кряк? В техпасспорте на Хаволин Синтетик тут, у всех вязкостей кроме 5w40 заявлен пурпоинт -36 такойже как у минерального Суприма. Непонятно... Может кто обьяснит что и как...
Не стоит так волноваться - все просто.
Во-первых методологически неверно ориентироваться на старый PDS 2010 года, когда давно есть новый с pp -42c.
MSDS. А MSDS говорит лишь следующее: Highly refined mineral oil (C15 - C50) Mixture 70 - 99 % weight.
Т.е. без кряка явно не обошлось а что там еще одному богу известно. Лаба показала основную химию как большинство современных почти что среднезольников + бор + моли + мало-мало магния.
Кряк от Шеврона это очень не плохо. Но я предпочитаю его же минералку с лошадиными дозами бора и молибдена.
Всё сказанное это о амеровском Шевроне, не европейце. Последний у меня не в почете.
ChevHavSyntUSENG.PDF
Изменено пользователем FeAll
Вс сказанное это о амеровском Шевроне, не европейце. Последний у меня не в почете.
Имеете в виду европейский Хаволайн? Почему не в почете?
Предыдущий опыт + похоже там не сам Шеврон раньше мешал, а кто-то из услужливых. По опыту и нескольким тестам европейцы были не очень. А сегодня там мощности Тексако в распоряжении Шеврона -- люди-машины. Неправильно думать, что прибрав Тексако Шеврон бросился все менять на свое и в части технологии, и оборудования, и снабжения - был завод, мешал, лил, продавал, ну и пусть мешает, льет-продает, только теперь со словом Шеврон. Маркетологи переупакуют, перемаркируют и понаприукрасят. Европейскому Шеврику нужно репутацию в моих глазах заработать. Это непросто :-)
Ничего научного в подтверждение своих слов привести не могу :unknw:
@FeAll, Спасибо большое. Правда, европейского Шеврона (это наверно который льётся в Бельгии) у нас не встречал. Минералка да, но и в минеральном Хаволин Мотор оил, если верить анализам PIQA, тоже большое содеражание молибдена и бора.
Да, я видел тот анализ амеровского Хаволина.
Мне Шеврон Люб-Тек написал, что у Хаволина (амеровского) чуть лучше базы чем у Суприма. Я так понял, что Суприм оставили на переходный период для консервативной части клиентов, кто реагирует на голубой цвет.
Европейского Хаволина не много но достаточно здесь. Выдает его в первую очередь литрово-кратная тара и широкое горло канистры в т.ч. литрухи.
А какие конкретно продукты? Что именно не понравилось? Что тесты показали?
просто присматриваюсь к Havoline Energy 5W-30
Мои ощущения систематизировать не буду, а в прессе поищи было не менее 2 тестов, может больше. Гуугл в помощь.
за полторы тысячи км на Chevron Delo 400 Synthetic 0W-30 масло по щупу на половину,вот так стойкость на угар :wacko: не подошло мне это масло :angry:
А Вам то зачем гидравлику в мотор заливать было? Взял бы тогда 5w30 из из линейки Delo.
эксперимент так сказать,прельстила незамерзайка эта америкосовская,каюсь теперь :vava:
а Delo 5W-30 и не встречалось ни где
ребят,может просрочка (на канистрах 05г)повлияла или на трассе съело (до 160км/ч) не проконтролировал этот момент :unknw:
Прекрасно прошлую зиму Chevron Delo 400 Synthetic 0W-30 отработал в дизеле Land-Cruiser 80, -35 заводился спокойно после ночной стоянки, больше проблем соляра доставляла. Одна проблема у местного поставщика порой нет того чего хочешь, везут дешман.
у вас же во Владивостоке есть дистрибутер http://www.wlbs.ru/production/chevron/ может закупка коробки -12 кварт или три галлона минимальный объем опта для них, позвони узнай, может напрямую затариваться будешь...Был бы у нулевки подтвержденный HTH>3.5 -лил бы на зиму
Изменено пользователем Vadim_Mk
Я у них и брал ведро 0ки, потом 3 месяца самых холодов откатал и остатки масла использовал в 2AZ-fe меньше его ел мотор.
