Масла Chevron
Масла Chevron
Официальный сайт: http://www.chevronlubricants.com/
Артикулы коды для заказа в инетмагазинах
Вариант № 1
223501482 - Chevron Havoline Motor Oil 0W-20 0,946L
076568796280 - Chevron Havoline Motor Oil 5W-20 0,946L
223393721 - Chevron Havoline Motor Oil 5W-20", 0.946L
223502482 - Chevron Havoline ProDS Full Synthetic 5W-20, 0.946L
223503482 - Havoline ProDS Full Synthetic 5W-30, 0.946L
223394485 - Chevron Havoline Motor Oil 5W-30, 4.73L
223394533 - Chevron Havoline Motor Oil 5W-30, 4.73L
076568796297 - Chevron Havoline Motor Oil 5W-30 0,946L
223726482 -  Chevron Havoline ProDS Full Synthetic 5W-40, 0.946L
223504482 - Chevron Havoline ProDS Euro Full Synthetic 5W-40, 0.946L
223395533 - Chevron Havoline Motor Oil 10W-30, 4.73L
223395481 - Chevron Havoline Motor Oil 10W-30, 0.946L
223396485 - Chevron Havoline Motor Oil 10W-40, 4.73L
223396481 - Chevron Havoline Motor Oil 10W-40, 0.946L
220135721 Chevron Supreme Motor Oil SAE 5W-20 946mL
220013533 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013553 Chevron Supreme Motor Oil SAE 5W-30 4,83L
220013429 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013719 Chevron Supreme Motor Oil SAE 5W-30 946mL
220155719 Chevron Supreme Motor Oil SAE 10W-30 946mL
220155533 Chevron Supreme Motor Oil SAE 10W-30 4,83L
220059533 Chevron Supreme Motor Oil SAE 10W-40 4,83L
220059429 Chevron Supreme Motor Oil SAE 10W-40 3,78L
220059719 Chevron Supreme Motor Oil SAE 10W-40 946mL
220060719 Chevron Supreme Motor Oil SAE 20W-50 946mL
220060533 Chevron Supreme Motor Oil SAE 20W-50 3,78L
257001388 - Chevron Delo 400 Syn XSP 5W-30 3,785 л
257001448 - Chevron Delo 400 Syn XSP 5W-30 18,9 л
257001981 - Chevron Delo 400 Syn XSP 5W-30 208 л
235195389 CHEVRON DELO 400 Synthetic SAE 0W-30 3,78L
271210339 CHEVRON DELO 400 LE Synthetic SAE 5W-30 3,78L
271210448 CHEVRON DELO 400 LE Synthetic SAE 5W-30 19L
271207448 CHEVRON DELO 400 LE Synthetic SAE 5W-40 19L
271207339 CHEVRON DELO 400 LE Synthetic SAE 5W-40 3,78L
222210339 CHEVRON DELO 400 LE 10W-30 3,78L
222210448 CHEVRON DELO 400 LE 10W-30 19L
222220721 CHEVRON DELO 400 LE 15W-40 946 mL
222220463 CHEVRON DELO 400 LE 15W-40 3,78L
222220478 CHEVRON DELO 400 LE 15W-40 9,946L
222220448 CHEVRON DELO 400 LE 15W-40 19L
224615463 CHEVRON DELO 400 SD SAE 15W-30 3,78L
224615448 CHEVRON DELO 400 SD SAE 15W-30 19L
235101448 CHEVRON DELO 400 Multigrade SAE 15W-40 19L
235101339 CHEVRON DELO 400 Multigrade SAE 15W-40 3,78L
235101721 CHEVRON DELO 400 Multigrade SAE 15W-40 946mL
271220722 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 946mL
271220448 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 19L
271220339 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 3,78L
Вариант №2
235101721           CHEVRON  DELO ® 400  15W-40 CI-4 plus       0.946л.
01020013           CHEVRON  DELO ® 400  15W-40 CI-4 plus       3.785л.
01020012           CHEVRON  DELO ® 400  15W-40 CI-4 plus      18.9л.
235101981           CHEVRON  DELO ® 400  15W-40 CI-4 plus      208л.
01020012           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      18.9л.
01020011           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      208л.
01020013           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus   3.785л.
235105339           CHEVRON  Delo®     400 MGX SAE 15W-40         3.785л.
235105428           CHEVRON  Delo®     400 MGX SAE 15W-40       18.9л.
235105981           CHEVRON  Delo®     400 MGX SAE 15W-40       208л.
8888880           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40     20л.
8888881           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40    208л.
271201448           CHEVRON URSA  SUPERPLUS  EC 15W-40    18.9л.
271201981           CHEVRON URSA  SUPERPLUS  EC 15W-40    208л.
222210448           DELO 400 LE 10W-30  18.9л.
222210981           DELO 400 LE 10W-30  208л.
222210339           DELO 400 LE 10W-30  3.785л.
01020048           DELO 400 LE 15W-40  0,946л.
222220448           DELO 400 LE 15W-40  18.9л.
222220981           DELO 400 LE 15W-40  208л.
222220463           DELO 400 LE 15W-40  3.785л.
271210448           DELO 400 LE SYNTHETIC 5W-30  18.9л.
271210981           DELO 400 LE SYNTHETIC 5W-30  208л.
271210339           DELO 400 LE SYNTHETIC 5W-30  3.785л.
271207448           DELO 400 LE SYNTHETIC 5W-40  18.9л.
271207981           DELO 400 LE SYNTHETIC 5W-40  208л.
271207339           DELO 400 LE SYNTHETIC 5W-40  3.785л.
235101721           DELO 400 MULTIGRADE 15W-40  0.946л.
235101448           DELO 400 MULTIGRADE 15W-40  18.9л.
235101981           DELO 400 MULTIGRADE 15W-40  208л.
235101339           DELO 400 MULTIGRADE 15W-40  3.785л.
01020051           DELO 400 SAE 10W  18.9л.
235109981           DELO 400 SAE 10W  208л.
01020051           DELO 400 SAE 40  18.9л.
235195351           DELO 400 SYNTHETIC 0W-30  0.946л.
235195448           DELO 400 SYNTHETIC 0W-30  18.9л.
235195981           DELO 400 SYNTHETIC 0W-30  208л.
235195389           DELO 400 SYNTHETIC 0W-30  3.785л.
01020047           DELO 400 XLE  Synblend 10W-30  18.9л.
01020007           DELO 400 XLE  Synblend 10W-30  208л.
01020048           DELO 400 XLE  Synblend 10W-30  3.785л.
254591542           CHEVRON BLACK PEARL GREASE  EP 2     397г
255659642           CHEVRON MOLY GREASE        EP NLGI 1     397г
01020290           CHEVRON MOLY GREASE        EP NLGI 1    182кг
255660642           CHEVRON MOLY GREASE        EP NLGI 2     397г
01020295           CHEVRON MOLY GREASE        EP NLGI 2    182кг
255660451           CHEVRON MOLY GREASE        EP NLGI 2   15.9кг
274509451           CHEVRON MULTIFAK                EP 00   15.9кг
01020303           CHEVRON MULTIFAK                EP 1     397г
01020302           CHEVRON MULTIFAK                EP 1   15.9кг
274503642           CHEVRON MULTIFAK                EP 2     397г
274503451           CHEVRON MULTIFAK                EP 2   15.9кг
01020218           CHEVRON RPM ARCTIC GREASE        EP NLGI 1    397г
01020218           CHEVRON RYKOTAC  GREASE        EP     397г
254504642           CHEVRON SRI GREASE        NLGI 2     397г
277111642           CHEVRON STARPLEX                EP 2     397г
250186642           CHEVRON ULTI-PLEX GREASE   EP NLGI 1     397г
250185642           CHEVRON ULTI-PLEX GREASE   EP NLGI 2     397г
250188642           CHEVRON ULTI-PLEX GREASE SYNT EP   1.5   397г
01020250           CHEVRON ULTRA-DUTY         EP NLGI 0     397г
238012642           CHEVRON ULTRA-DUTY         EP NLGI 1     397г
238011642           CHEVRON ULTRA-DUTY         EP NLGI 2     397г
235212451           DELO GREASE EP NLGI 00  15.9кг.
01020218           DELO GREASE EP NLGI 1  397г.
235208451           DELO GREASE EP NLGI 2  15.9кг.
235208642           DELO GREASE EP NLGI 2  397г.
01020218           DELO GREASE ESI  397г.
222206642           DELO HEAVY DUTY  EP 2  397г.
222231451           DELO HEAVY DUTY MOLY 3%  EP 2  15,9кг.
01020205           CHEVRON 2 CYCLE OIL             TC-W3     18,9л
01020204           CHEVRON 2 CYCLE OIL             TC-W3  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/20  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/30  0.946л
01020158           CHEVRON SUPREME 100% SYNTHETIC   5/40  0.946л
01020152           CHEVRON SUPREME 100% SYNTHETIC  10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL         5/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/40  0.946л
01020142           CHEVRON SUPREME MOTOR OIL          30  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/20  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/30  0.946л
01020102           CHEVRON SUPREME MOTOR OIL        5/30  3.785л
01020113           CHEVRON SUPREME MOTOR OIL       10/30  0.946л
01020111           CHEVRON SUPREME MOTOR OIL       10/30  208л.
01020112           CHEVRON SUPREME MOTOR OIL       10/30  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/30  4,73 л
01020123           CHEVRON SUPREME MOTOR OIL       10/40  0.946л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  4,73 л
01020133           CHEVRON SUPREME MOTOR OIL       20/50  0.946л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  3.785л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  4,73 л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O   5/30  0.946л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O 10/30  0.946л
SAIC-GM Full Synthetic 0W-20 Chevron-Tianjin Made in China
SAIC-GM Full Synthetic 5W-30 Chevron-Tianjin Made in China
Chevron Delo 400 Syn XSP 5W-30 API CK-4
Chevron Delo LE 400 5W-40
Chevron Delo LE 400 5W-30
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2
Лабораторные анализы - Отработки - UOAoil-club.ru
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2 отработка на Toyota Rav4 после 9460км
Chevron Delo 400LE Synthetic 5W-40 отработка на Dodge Ram 2500 после 8200 км.
Chevron Delo 400 XLE Synblend 10W-30 CJ-4 отработка на Ford Focus ST после 8000 км.
Chevron Delo 400 LE Synthetic 5W-40 отработка на Dodge Ram после 16790 км.
2 минуты назад, SL1 сказал:
PC SS получше будет, т.к. чистая синтетика
Кряк
12 часов назад, SL1 сказал:
Процес получения II группы у Шеврон этапный, в отличии от XOM, кстати. Сначала производится группа I. Вот ее и бодяжат с группой III или II+ с целью снижения стоимости конечного продукта. Так получают полусинтетику и не только Шеврон. Загляните еще раз в MSDS, основная база там без гидроочистки.
А вы вот это вот заявление, что Chevron бодяжит I-ю группу с III можете как-то подтвердить?
Пока получается, что Шеврон торгует II, III, IV группой, расказывает как они умеют на своей II обскакивать других с третьей, но втихаря, в свои продукты, подмешивает I группу...
Хочется аргументов с вашей стороны.
А пока вот не поленился, посмотрел несколько продуктов от Chevron:
Chevron Supreme Motor Oil SAE 5W-20, 5W-30, 10W-30
Highly refined mineral oil (C15 - C50) - 70-99%
Chevron Supreme Synthetic Blend Motor Oil SAE 5W-20
Chevron Supreme Synthetic Blend Motor Oil SAE 5W-30
Chevron Supreme Synthetic Euro Motor Oil SAE 5W-4
Havoline High Mileage Motor Oil SAE 0W-20, 5W-20, 5W-30, 10W-30
Havoline Motor Oil SAE 5W-20 (GF-5)
Havoline ProDS Full Synthetic Euro Motor Oil SAE 5W-40
Havoline ProDS Full Synthetic Motor Oil SAE 0W-20, 5W-20, 5W-30
Из TDS на базовые масла Chevron:
Chevron Neutral Oils are all-hydroprocessed, Group II/II+ paraffinic base oils that can be used in blending in a variety of lubricant and process oils.
Chevron Neutral Oils are all-hydroprocessed, highly refined API Group II/II+ paraffinic base stocks. Their extremely low sulfur, nitrogen, and
aromatic content give them excellent thermal and oxidation stability. These base oils provide excellent cold flow performance because the
ISODEWAXING® catalyst and technology convert almost all of the wax in the feed into very stable, branched isoparaffins.
Chevron Neutral Oils 150R, 220R, and 600R are API Group II base stocks with a typical viscosity index of 99-103.
Chevron Neutral Oil 100R is a 5 cSt Group II "plus" base stock with a typical viscosity index of 116-119. It was designed to meet the strict volatility
requirements of modern engine oils while maintaining API Group II status to simplify qualification programs and to provide interchangeability of
Chevron base stocks with other approved stocks. Chevron 100R enables blenders to minimize the amount of more expensive Group III oils needed
for the most stringent 10W-XX, 5W-XX and 0W-XX motor oil requirements. Chevron 100R was upgraded to match the specifications of Chevron 110RLV,
which has been sunset.
Изменено пользователем Texacoman
Texacoman У Шеврона и минеральные продукты есть и не обязательно моторные масла, но и трансмиссионные и гидравлика. А если вспомнить уважаемого SAE20, то он говорил, что группа II в моторном масле имеет не только преимущества перед I, но и недостатки. При перекате, перегреве и т.п. она больше подвержена образованию sludge, если я правильно помню, желируется в сгустках. Применять ее как базу PCMO в чистом виде не так уж и хорошо. Возможно, это тоже аргумент за смесь I+III (I+II+).
13 минут назад, Texacoman сказал:
И что из того, что чистые или белые базовые масла Шеврон получает гидроочисткой и использует их в моторных маслах с наиболее жесткими требованиями? Не думаю, что к таким относятся минеральные и полусинтетические масла. Все компании любят рекламировать свои наиболее передовые технологии и продукты не отказываясь от низкобюджетных и традиционных.
Изменено пользователем SL1
SL1 , я что-то вас не понимаю уже. Я попросил предоставить подтверждение ваших слов о применении в легкомоторных маслах, и 5W-30 в частности, базовых масел I группы, а вы мне говорите про то, что SAE 20 что-то там говорил...
Я не читал. Полагаю, что у компании Chevron есть свои SAE 20 и они там тоже что-то думают.
Читаю паспорт на рекомендованную вами синтетическую петроканаду.
"hydrotreated neutral oil-based" - это переводится как синтетическая база?
2 часа назад, Texacoman сказал:
03.06.2020 в 17:16, SL1 сказал:
А так да, 5W-30 SN Plus полусинтетических много. 75% минералки + 15% гидрокрекинга группы III. CAM2, например:
http://www.cam2.com/catalog/engine-oil/high-mileage/protect75-high-mileage-synthetic-blend-motor-oil-5w-30/
http://www.cam2.com/userfiles/productLiterature/CAM2-PCMO-MotorOil-SDS.pdf
5 минут назад, SL1 сказал:
Согласитесь, что то, что делает некий CAM2 - это не аргумент. При чём тут Шеврон? Мы же тут не гипотетические возможности обсуждаем, а конкретно Шеврон.
4 минуты назад, Texacoman сказал:
Тогда покажите msds, где у сабжевого полусинтетического масла написано, что вся база там после гидроочистки. Я свой пример привел.
3 минуты назад, SL1 сказал:
Вы никаких примеров не приводили. САМ2 - не пример. Вы заявили, что Шеврон делает свою вторую группу из I и III.
Я попросил доказательств.
47 минут назад, Texacoman сказал:
52 минуты назад, SL1 сказал:
Да я, в общем то, в основном, опровергал Ваши доводы относительно того, что 5/30 API SN+ делается только на гидроочищенной второй группе, что Шевроновская полусинтетика не содержит минералки гр. 1 и т.п. Не убедительные они. А так да, 5/30 API SN+ может быть и на смеси 1+3 и только на группе 2/2+, и Шеврон запросто может его делать именно так, без группы 1, но подтверждения этому пока нет.
7 часов назад, SL1 сказал:
Этот момент не уловил в его постах, а если и прочел, мог не придать данному посту нужное внимание:unknw:, на битоге встречал пост, где SonofJoe ратовал за II группу, как идеал базы, или я, так смог прочесть в гуглопереводе, или хотел именно так, читать пост:unknw:, внутрене для себя, начинаю понемногу считать, что 2гр. - это золотая середина
Изменено пользователем ss333
3 часа назад, ss333 сказал:
Этот момент не уловил...
Это странный "момент". Особенно, если вспомнить, что группы II и III - суть одно и то же, а масел на 100% ПАО почти нет, то остаётся очищенная минералка. И, получается, именно она лучший выбор.
Очень сомневаюсь. Это противоречит тому, что мы видим в реальном мире.
25 минут назад, Texacoman сказал:
Имеете в виду первую группу "Ib group"?
17 минут назад, ss333 сказал:
Я про API group I.
