Масла BP
Гость saa182
Масла BP
Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html
119368 / 15805A Visco 7000 0W-40 1L
119369 / 15805B Visco 7000 0W-40 4L
117528 / 15804F Visco 7000 0W-40 60L
117386 / 15804E Visco 7000 0W-40 208L
14F697 / 15571C Visco 5000 5W-30 1L
14F69B / 15571D Visco 5000 5W-30 4L
14F69C / 15570F Visco 5000 5W-30 60L
14EE20 / 15571A Visco 5000 5W-30 208L
114496 / 15805F Visco 5000 5W-40 1L
114502 / 15806A Visco 5000 5W-40 4L
108963 / 15805E Visco 5000 5W-40 60L
108959 / 15805D Visco 5000 5W-40 208L
14DF28 / 15870C Visco 3000 Diesel 10W-40 1L
14DF29 / 15870D Visco 3000 Diesel 10W-40 4L
119777 / 15870B Visco 3000 Diesel 10W-40 60L
119634 / 15870A Visco 3000 Diesel 10W-40 208L
14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L
14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L
14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L
14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L
14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L
14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L
14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L
14FA20 Visco 2000 A3/B3 15W-40 60L
14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L
15267A / 1550F9 Vanellus Max 5W-30 208L
15267C / 1550F6 Vanellus Max 5W-30 20L
15267D / 1550F3 Vanellus Max 5W-30 5L
1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L
1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L
1527F6 / 1553CE Vanellus Max 10W-40 208L
1527F8 / 1553CD Vanellus Max 10W-40 20L
1527FB Vanellus Max 10W-40 5L
1525F0 / 1554FF Vanellus Multi A 10W-40 208L
1525EF / 1554FD Vanellus Multi A 10W-40 20L
1525F2 / 1554FA Vanellus Multi A 10W-40 5L
1525EB / 1552EB Vanellus Multi A 15W-40 208L
1525EA / 1552DB Vanellus Multi A 15W-40 20L
14E2AF Vanellus Multigrade 15W-40 208L
14E2B0 Vanellus Multigrade 15W-40 20L
15282A / 15552B Vanellus Multi 15W-40 208L
15282B / 15551C Vanellus Multi 15W-40 20L
15260C / 15549E Vanellus Mono 10W 208L
15269D / 154FE2 Vanellus Mono 30 208L
14342B Autran DX III 1L
1434A7 Autran DX III 20L
107042 Autran DX III 208L
14340E Autran MBX 1L
116163 / 15646C Autran MBX 20L
107068 Autran MBX 208L
119040 Autran MM-SP III 20L
119041 Autran MM-SP III 208L
117141 Autran 4 10 208L
114801 Autran 4 30 208L
14340A Energear SGX 75W-90 1L
116282 Energear SGX 75W-90 20L
108549 Energear SGX 75W-90 208L
14340D / 1557FC Energear HT 75W-90 1L
152B37 / 1557FD Energear HT 75W-90 20L
112212 / 1557FE Energear HT 75W-90 208L
14342A Energear HT 80W-90 1L
116204 Energear HT 80W-90 20L
107544 Energear HT 80W-90 208L
112224 Energear HT 85W-140 208L
1433FC / 15573C Energear EP 80W-90 1L
116100 / 15573B Energear EP 80W-90 20L
107481 / 15573A Energear EP 80W-90 208L
14973D / 15554C Energear EP 80W 208L
14340C Energear Limslip 90 1L
110198 / 1557F8 Energear Limslip 90 208L
1433FE / 155D2A Energear Hypo 80W-90 1L
116106 / 155D1A Energear Hypo 80W-90 20L
107520 / 155D1C Energear Hypo 80W-90 208L
107527 Energear Hypo 85W-140 208L
116107 Energear Hypo 85W-140 20L
107534 / 1556ED Energear Hypo 90 208L
116108 Energear Hypo 90 20L
119622 / 1556F7 Energear SHX-M 75W-90 208L
119624 / 1556FA Energear SHX-M 75W-90 20L
14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L
109101 Energrease ZS 00 15KG
109107 Energrease ZS 00 50KG
135603 Brake Fluid DOT 4 0.5L
BP Visco 7000 0W-40 CleanGuard свежее
BP Visco 5000 5W-40 свежее
BP VISCO 3000 10W-40 свежее
BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км
BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км
BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км
BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч
BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
сколько жрет?
короче жрет около 1-1.5 на 10 000
компрессия большая какая то...по 14 очков во всех.
а есть разница? и что значит сервисный?
Это значит, что разлит в лучшей рецептуре (насколько можно ждать от ширпотребного масла от BP) для данной серии, не в третьей стране специально для автосервисов, в том числе для гарантийного обслуживания.
Судя по многому написанному в этом форуме и не только, есть разница по рецептуре, иногда и по месту поизводства - у розничных продуктов Castrol точно (с BP надо разбираться, но им принадлежит Castrol, и они им управляют, заводы в поставках для России одни и те же) - особенно, если сравнивать розницу для третьих стран с сервисным/профешэнл маслом.
Это значит, что разлит в лучшей рецептуре не в третьей стране специально для автосервисов, в том числе для гарантийного обслуживания.
а я захотел вот на другое какое нибудь перейти
ибо как мне подсказал кто то, что масло БП не любит высокие обороты...
слышал мнение что мотор D16a так и должен есть хотя хз, у меня такой же мотор пробег правда 180т. расход получается как у тебя 100-150гр на 1000км, при пробеге 100т.км. вроде расход такой же был, при увеличение расхода применяю регулярно раскоксовку, пока вроде стабильно пфу 3 раза, а масло ты зря собираешься менять если в двиге чисто я бы ездил, хотя от него может тоже расход чуть больше быть, в общем есть желание пробуй...пиши))
интересный вовод... правда какими домыслами он подтверждён ?? замерами давки при 8000об? ....
глянул вчера в горловину , пошарил там пальцем и повеселел, нет даже заликовал после того как посветил глубоко фонариком, после слитого родного масла, стенки были покрыты сажей, результат сервисных интервалов -10тык всёже для города велики...
теперь стенки просто блестят, не вижу ни лака ни сажи, при этом масло значительно потемнело, как гречичный мёд...
markii Так и должно быть - ПАО масла моют так,что мама не горюй, люди даже когда их заливают в "загаженные" моторы при первой смене меняют по три четыре масляных фильтра за первую тысячу пробега(ибо забиваются полностью какой).
очзлобный да ну? :) Зачем тогда моющие присадки таким маслам. :) Мое мнение (основанное на использованиях кряковых масел правда и вскрытия после них) что масла моют лучше те в которых щелочное выше и вообще масла моют посредственно. Примерно как холодная вода моет пригаревшую жирную сковородку...
Добавлю, что во всех вариантах поиска по моторным маслам Visco не вижу в MSDS прямого упоминания про пао, хотя если пурпойнт честная у 0w40 (надо проверять как-то кому погода позволяет) - там вероятно.
torcon чуть посильнее с учетом щелочного и все же некоей небольшой присущей агрессивности самого масла к наработанным шлакам, но далеко не как в рекламе про Фэри или АОС.
Можно говорить об ополаскивании хорошем с эффектом легкого грубого мытья кроме откровенного слуджа (тут быстро не уберется - и не за одну смену масла), а также кроме прикипевшего и прикаменевшего.
torcon все основано только на опыте(наблюдаю уже семь автомобилей на ПАО) Rallyst как показывает практика все таки моют они очень прилично(Если чел будет вскрывать клапанную крышку - то постараюсь сфотать что получилось,тем более то что было тут многие видели - в теме про масла Лукойл)
очзлобный есть какая-нибудь личная статистика по хону/износу/пробегу при использовании масел на пао-базе? В сравнении с хорошими кряковыми.
visco_7000_0w_40_1_.pdf Прототип наклейки BP Visco 0w-40 для Евросоюза, made in EU. Штрих-код Германии.
В списке нет России и прочих.
Пур пойнт обещана -57, на ряде российских сайтов кстати тоже такая часто, хотя и там одинаковости нет (не -60 как в более поздней на год-два документации torcona, но и страны разные).visco_7000_1006.pdfvisco7000_f_0108.pdfОперируя только документами, сформированными первоисточником BP, вижу разные MSDS и потребительские мануалы, ТТХ различаются не только по пур пойнт.
В одном словенском MSDS: -46, а есть тоже в словенском более поздней даты -63:
VISC7000.DOC Visco_7000_0W_40.docОбращаем внимание на даты и на ключевые присадки.
И на закуску для сравнения ТТХ с сайта грузинского дистрибьютера:
visco_7000_0w40.doc
Честная там пурпоинт markii уже проверена пару раз при -44 -47 - она текет в узкой пробирке(!)
