Масла BP
Гость saa182
Масла BP
Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html
119368 / 15805A Visco 7000 0W-40 1L
119369 / 15805B Visco 7000 0W-40 4L
117528 / 15804F Visco 7000 0W-40 60L
117386 / 15804E Visco 7000 0W-40 208L
14F697 / 15571C Visco 5000 5W-30 1L
14F69B / 15571D Visco 5000 5W-30 4L
14F69C / 15570F Visco 5000 5W-30 60L
14EE20 / 15571A Visco 5000 5W-30 208L
114496 / 15805F Visco 5000 5W-40 1L
114502 / 15806A Visco 5000 5W-40 4L
108963 / 15805E Visco 5000 5W-40 60L
108959 / 15805D Visco 5000 5W-40 208L
14DF28 / 15870C Visco 3000 Diesel 10W-40 1L
14DF29 / 15870D Visco 3000 Diesel 10W-40 4L
119777 / 15870B Visco 3000 Diesel 10W-40 60L
119634 / 15870A Visco 3000 Diesel 10W-40 208L
14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L
14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L
14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L
14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L
14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L
14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L
14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L
14FA20 Visco 2000 A3/B3 15W-40 60L
14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L
15267A / 1550F9 Vanellus Max 5W-30 208L
15267C / 1550F6 Vanellus Max 5W-30 20L
15267D / 1550F3 Vanellus Max 5W-30 5L
1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L
1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L
1527F6 / 1553CE Vanellus Max 10W-40 208L
1527F8 / 1553CD Vanellus Max 10W-40 20L
1527FB Vanellus Max 10W-40 5L
1525F0 / 1554FF Vanellus Multi A 10W-40 208L
1525EF / 1554FD Vanellus Multi A 10W-40 20L
1525F2 / 1554FA Vanellus Multi A 10W-40 5L
1525EB / 1552EB Vanellus Multi A 15W-40 208L
1525EA / 1552DB Vanellus Multi A 15W-40 20L
14E2AF Vanellus Multigrade 15W-40 208L
14E2B0 Vanellus Multigrade 15W-40 20L
15282A / 15552B Vanellus Multi 15W-40 208L
15282B / 15551C Vanellus Multi 15W-40 20L
15260C / 15549E Vanellus Mono 10W 208L
15269D / 154FE2 Vanellus Mono 30 208L
14342B Autran DX III 1L
1434A7 Autran DX III 20L
107042 Autran DX III 208L
14340E Autran MBX 1L
116163 / 15646C Autran MBX 20L
107068 Autran MBX 208L
119040 Autran MM-SP III 20L
119041 Autran MM-SP III 208L
117141 Autran 4 10 208L
114801 Autran 4 30 208L
14340A Energear SGX 75W-90 1L
116282 Energear SGX 75W-90 20L
108549 Energear SGX 75W-90 208L
14340D / 1557FC Energear HT 75W-90 1L
152B37 / 1557FD Energear HT 75W-90 20L
112212 / 1557FE Energear HT 75W-90 208L
14342A Energear HT 80W-90 1L
116204 Energear HT 80W-90 20L
107544 Energear HT 80W-90 208L
112224 Energear HT 85W-140 208L
1433FC / 15573C Energear EP 80W-90 1L
116100 / 15573B Energear EP 80W-90 20L
107481 / 15573A Energear EP 80W-90 208L
14973D / 15554C Energear EP 80W 208L
14340C Energear Limslip 90 1L
110198 / 1557F8 Energear Limslip 90 208L
1433FE / 155D2A Energear Hypo 80W-90 1L
116106 / 155D1A Energear Hypo 80W-90 20L
107520 / 155D1C Energear Hypo 80W-90 208L
107527 Energear Hypo 85W-140 208L
116107 Energear Hypo 85W-140 20L
107534 / 1556ED Energear Hypo 90 208L
116108 Energear Hypo 90 20L
119622 / 1556F7 Energear SHX-M 75W-90 208L
119624 / 1556FA Energear SHX-M 75W-90 20L
14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L
109101 Energrease ZS 00 15KG
109107 Energrease ZS 00 50KG
135603 Brake Fluid DOT 4 0.5L
BP Visco 7000 0W-40 CleanGuard свежее
BP Visco 5000 5W-40 свежее
BP VISCO 3000 10W-40 свежее
BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км
BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км
BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км
BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч
BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
дата на той канистре, что я взял - 01/04/2011
То ли 4-е января, то ли первое апреля :)
Тогда это мистика))) Или может BP делает по спец заказам масло? Ну в смысле их попросили сделать там 5000 канистр для сети какой то, они сделали, и цену свою обговорили?
Х.з. что у них в МЕТРО происходит. Там и LM Synthoil High Tech 5W-40 (канистра со значком GVO)в районе 1400р. за 4л, при средней цене по городу в районе 2 тыс.
А Валволинчика там нету? :rolleyes:
Кастрол с БП и мобил с эссо. Ну и как-то LM затесался с Полусинью Луковую.
Кстати, интересные цены там только на BP 7000 и LM Synthoil High Tech 5W-40, все остальное дороже чем в автомагазинах ну или как в них. Тот же магнатек 5-40 С3 стоит около 1,4-1,5 рублей за четверку.
, давно уже затесались. У немцев давно практикуется продавать через супермаркеты.
На заправках ВР иногда видел акции типа Виско 5000 4л+1л комплект по низкой цене, и 7000 4л по низкой цене, цифры не запомнил, но запомнил что дешево. Не брал, т.к. уже залитое полностью устраивает.
Периодически скидывают ценник везде походу, в сетях супермаркетов и на заправках. А вот у барыг низких цен быть не может :spiteful:
Если попалось масло по акции, лучше взять да побольше :spiteful:
Был в Москве на Щелковском шоссе в Метро - нету BP Visco 7000 вообще, может все смели уже... и из акций по маслам только на Castrol Magnatec Diesel 5W-40, Castrol Magnatec 5W-40 + Castrol TBE и Liqui Moly Longtime High Tech 5W-30. Цены точно не помню, но все где-то по 1200-1400. Завтра еще попробую на Новорязанское шоссе заскочить.
А на ebay.de не знают такого масла. Там вообще виско не продают.
Как это не знают, не продают - например, 7000 три кряка разной вязкости из Испании.
@fromin, ну это единичный случай,этож всётаки аукцион, тут и эксклюзивы есть.. посмотри в каких масштабах там продаётся вальволин, шелл, эльф.
Поехал сегодня опять в МЕТРО, думаю закуплюсь виской, пока акция. Приехал. Вчера был заставлен весь стелаж, сегодня - пустота. Ладно догадался вниз заглянуть, там в конце стояло пару канистр. Под изумленным взглядом мужика, выбиравшего мобил, почти полностью залез под стелаж и достал эти последние две канистры. Вот как-то так. Халява кончилась.
