Масла BP
Гость saa182
Масла BP
Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html
119368 / 15805A Visco 7000 0W-40 1L
119369 / 15805B Visco 7000 0W-40 4L
117528 / 15804F Visco 7000 0W-40 60L
117386 / 15804E Visco 7000 0W-40 208L
14F697 / 15571C Visco 5000 5W-30 1L
14F69B / 15571D Visco 5000 5W-30 4L
14F69C / 15570F Visco 5000 5W-30 60L
14EE20 / 15571A Visco 5000 5W-30 208L
114496 / 15805F Visco 5000 5W-40 1L
114502 / 15806A Visco 5000 5W-40 4L
108963 / 15805E Visco 5000 5W-40 60L
108959 / 15805D Visco 5000 5W-40 208L
14DF28 / 15870C Visco 3000 Diesel 10W-40 1L
14DF29 / 15870D Visco 3000 Diesel 10W-40 4L
119777 / 15870B Visco 3000 Diesel 10W-40 60L
119634 / 15870A Visco 3000 Diesel 10W-40 208L
14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L
14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L
14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L
14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L
14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L
14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L
14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L
14FA20 Visco 2000 A3/B3 15W-40 60L
14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L
15267A / 1550F9 Vanellus Max 5W-30 208L
15267C / 1550F6 Vanellus Max 5W-30 20L
15267D / 1550F3 Vanellus Max 5W-30 5L
1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L
1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L
1527F6 / 1553CE Vanellus Max 10W-40 208L
1527F8 / 1553CD Vanellus Max 10W-40 20L
1527FB Vanellus Max 10W-40 5L
1525F0 / 1554FF Vanellus Multi A 10W-40 208L
1525EF / 1554FD Vanellus Multi A 10W-40 20L
1525F2 / 1554FA Vanellus Multi A 10W-40 5L
1525EB / 1552EB Vanellus Multi A 15W-40 208L
1525EA / 1552DB Vanellus Multi A 15W-40 20L
14E2AF Vanellus Multigrade 15W-40 208L
14E2B0 Vanellus Multigrade 15W-40 20L
15282A / 15552B Vanellus Multi 15W-40 208L
15282B / 15551C Vanellus Multi 15W-40 20L
15260C / 15549E Vanellus Mono 10W 208L
15269D / 154FE2 Vanellus Mono 30 208L
14342B Autran DX III 1L
1434A7 Autran DX III 20L
107042 Autran DX III 208L
14340E Autran MBX 1L
116163 / 15646C Autran MBX 20L
107068 Autran MBX 208L
119040 Autran MM-SP III 20L
119041 Autran MM-SP III 208L
117141 Autran 4 10 208L
114801 Autran 4 30 208L
14340A Energear SGX 75W-90 1L
116282 Energear SGX 75W-90 20L
108549 Energear SGX 75W-90 208L
14340D / 1557FC Energear HT 75W-90 1L
152B37 / 1557FD Energear HT 75W-90 20L
112212 / 1557FE Energear HT 75W-90 208L
14342A Energear HT 80W-90 1L
116204 Energear HT 80W-90 20L
107544 Energear HT 80W-90 208L
112224 Energear HT 85W-140 208L
1433FC / 15573C Energear EP 80W-90 1L
116100 / 15573B Energear EP 80W-90 20L
107481 / 15573A Energear EP 80W-90 208L
14973D / 15554C Energear EP 80W 208L
14340C Energear Limslip 90 1L
110198 / 1557F8 Energear Limslip 90 208L
1433FE / 155D2A Energear Hypo 80W-90 1L
116106 / 155D1A Energear Hypo 80W-90 20L
107520 / 155D1C Energear Hypo 80W-90 208L
107527 Energear Hypo 85W-140 208L
116107 Energear Hypo 85W-140 20L
107534 / 1556ED Energear Hypo 90 208L
116108 Energear Hypo 90 20L
119622 / 1556F7 Energear SHX-M 75W-90 208L
119624 / 1556FA Energear SHX-M 75W-90 20L
14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L
109101 Energrease ZS 00 15KG
109107 Energrease ZS 00 50KG
135603 Brake Fluid DOT 4 0.5L
BP Visco 7000 0W-40 CleanGuard свежее
BP Visco 5000 5W-40 свежее
BP VISCO 3000 10W-40 свежее
BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км
BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км
BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км
BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч
BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
Если точнее интересуют 0-40 и 5-40 - я в теме новый, подскажите где почитать за что и какая присадка отвечают в масле. Вроде описано что БП тот же Арал, но в арале нету молибдена - вот и читаю щас зачем он мне?
500 рублей 4 литра? о_О
вот ссылка на другой форум сообщение http://lanos-club.ru/forum/index.php?showtopic=16815&view=findpost&p=429150
Visco 7000 0W40 сравнивать с Visco 5000 5W40 все равно что сравнить белаз и боинг 747 :D Оба масла по своиму хороши. Общее одно - чем выше число в линейки Visco X000 тем "топовее" масло.
Изменено пользователем DIman
@VampeerCo, BP Visco 7000 0W-40 это настоящая синтетика Пао, хорошее масло за свои деньги. Но есть особенность низкое/среднее щелочное число для сбережения современных катализаторов - если у тебя их нет - то тебе и сберегать нечего.
Visco 5000 5W-40 - гидрокрекинг (база имеющая минеральную основу) - если на прилавках 1100-1200 за 4 литра то это масло того стоит.
Лучше конечно первое, но не всегда и не во всех вариантах. По износу, угару и остальных эксплуатационным характеристикам - будет примерно одинаково.
Интересно, что из московских магазинов почти исчезли масла BP.
Разве что остатки или на заправках BP, а так всё больше Castrol.
Правильно,зато больше появится канистр ARAL,им же надо как-то масло BP продавать.
Здравствуйте. У меня вопрос почему Visco 5w-30 нету на сайте bp если он есть в продаже и вообще мало инфы о нем. И можно ли заменить visco 7000 Visco 7000 Turbo Diesel для бензиновых двигателей так как хочется побольше щелочного числа? Спасибо
что-то помоему уже не единожды писали, что виско 7000 подкакивает в движке. или не?
у меня подкакивало(а именно индикатором является маслозаливная крышка с обратной стороны)5000,с 7000й все нормально
Но ты бы слышал как на нем работает движек..ммммм...поет! И крутиться кстати тоже очень легко!
паддержу. Даже дизель, даже в гараже тише урчит :rolleyes:
я, конечно, уже и не помню как на предыдущем масле было, но на этом мне нра.
может из-за пао и молибдена ? на Тотеке тоже все замечают, что двигатели много тише работают. Сравним :rolleyes:
вязкость пониже обычной сороковки, вот и поёт)
Дело не в вязкости, а в модификаторах трения, у Вольвика 0-40 тоже 12.7 Сст при 100С, Авс заметил более громкую работу двигателя на нем после мобила...
