Масла BP
Гость saa182
Масла BP
Официальный сайт: http://www.bp.com/en_gb/lubricants/united-kingdom.html
119368 / 15805A Visco 7000 0W-40 1L
119369 / 15805B Visco 7000 0W-40 4L
117528 / 15804F Visco 7000 0W-40 60L
117386 / 15804E Visco 7000 0W-40 208L
14F697 / 15571C Visco 5000 5W-30 1L
14F69B / 15571D Visco 5000 5W-30 4L
14F69C / 15570F Visco 5000 5W-30 60L
14EE20 / 15571A Visco 5000 5W-30 208L
114496 / 15805F Visco 5000 5W-40 1L
114502 / 15806A Visco 5000 5W-40 4L
108963 / 15805E Visco 5000 5W-40 60L
108959 / 15805D Visco 5000 5W-40 208L
14DF28 / 15870C Visco 3000 Diesel 10W-40 1L
14DF29 / 15870D Visco 3000 Diesel 10W-40 4L
119777 / 15870B Visco 3000 Diesel 10W-40 60L
119634 / 15870A Visco 3000 Diesel 10W-40 208L
14F6E7 / 157F38 Visco 3000 A3/B4 10W-40 1L
14F6E4 / 157F36 Visco 3000 A3/B4 10W-40 4L
14F6E2 / 157F35 Visco 3000 A3/B4 10W-40 20L
14F6E6 / 157F37 Visco 3000 A3/B4 10W-40 60L
14F6E1 / 157F34 Visco 3000 A3/B4 10W-40 208L
14FA23 / 156DA8 Visco 2000 A3/B3 15W-40 1L
14FA26 / 156DAA Visco 2000 A3/B3 15W-40 5L
14FA20 Visco 2000 A3/B3 15W-40 60L
14FA1D / 156DA6 Visco 2000 A3/B3 15W-40 208L
15267A / 1550F9 Vanellus Max 5W-30 208L
15267C / 1550F6 Vanellus Max 5W-30 20L
15267D / 1550F3 Vanellus Max 5W-30 5L
1525F6 / 1552B1 Vanellus Max Eco 10W-40 208L
1525F7 / 1552B0 Vanellus Max Eco 10W-40 20L
1527F6 / 1553CE Vanellus Max 10W-40 208L
1527F8 / 1553CD Vanellus Max 10W-40 20L
1527FB Vanellus Max 10W-40 5L
1525F0 / 1554FF Vanellus Multi A 10W-40 208L
1525EF / 1554FD Vanellus Multi A 10W-40 20L
1525F2 / 1554FA Vanellus Multi A 10W-40 5L
1525EB / 1552EB Vanellus Multi A 15W-40 208L
1525EA / 1552DB Vanellus Multi A 15W-40 20L
14E2AF Vanellus Multigrade 15W-40 208L
14E2B0 Vanellus Multigrade 15W-40 20L
15282A / 15552B Vanellus Multi 15W-40 208L
15282B / 15551C Vanellus Multi 15W-40 20L
15260C / 15549E Vanellus Mono 10W 208L
15269D / 154FE2 Vanellus Mono 30 208L
14342B Autran DX III 1L
1434A7 Autran DX III 20L
107042 Autran DX III 208L
14340E Autran MBX 1L
116163 / 15646C Autran MBX 20L
107068 Autran MBX 208L
119040 Autran MM-SP III 20L
119041 Autran MM-SP III 208L
117141 Autran 4 10 208L
114801 Autran 4 30 208L
14340A Energear SGX 75W-90 1L
116282 Energear SGX 75W-90 20L
108549 Energear SGX 75W-90 208L
14340D / 1557FC Energear HT 75W-90 1L
152B37 / 1557FD Energear HT 75W-90 20L
112212 / 1557FE Energear HT 75W-90 208L
14342A Energear HT 80W-90 1L
116204 Energear HT 80W-90 20L
107544 Energear HT 80W-90 208L
112224 Energear HT 85W-140 208L
1433FC / 15573C Energear EP 80W-90 1L
116100 / 15573B Energear EP 80W-90 20L
107481 / 15573A Energear EP 80W-90 208L
14973D / 15554C Energear EP 80W 208L
14340C Energear Limslip 90 1L
110198 / 1557F8 Energear Limslip 90 208L
1433FE / 155D2A Energear Hypo 80W-90 1L
116106 / 155D1A Energear Hypo 80W-90 20L
107520 / 155D1C Energear Hypo 80W-90 208L
107527 Energear Hypo 85W-140 208L
116107 Energear Hypo 85W-140 20L
107534 / 1556ED Energear Hypo 90 208L
116108 Energear Hypo 90 20L
119622 / 1556F7 Energear SHX-M 75W-90 208L
119624 / 1556FA Energear SHX-M 75W-90 20L
14B5E2 / 154FC7 Energear SHX-LS 75W-90 208L
109101 Energrease ZS 00 15KG
109107 Energrease ZS 00 50KG
135603 Brake Fluid DOT 4 0.5L
BP Visco 7000 0W-40 CleanGuard свежее
BP Visco 5000 5W-40 свежее
BP VISCO 3000 10W-40 свежее
BP Visco 7000 0W-40 LL-04 C3 отработка на BMW 525D после 10100км
BP Visco 7000 0W-40 отработка на Fiat Linea после 7000км
BP Visco 7000 0W-40 C3 отработка + Liqui Moly Oil Additive на Mitsubishi Outlander XL после 4500км
BP Visco 5000 5W-40 на Лада Калина (Учебка) после 12000км и 1200м.ч
BP Visco 7000 0W-40 LL-04 C3 отработка на VW Tiguan после 8300км
Судя по анализам у Visco 3000 необычайно жирный пакет присадок, с бором и молибденом. Я то смотрю люди ездят и не жалуются.
Изменено пользователем vital_xbc
Вот я года за 2-2,5 на BP Visco 5000 5W-40 около 40 т км откатал, соответственно 4 замены по 10 тык. Потом полез менять прокладку клапанной крышки и прозрел сколько было нагара на крышке и лака на валах. Моё мнение, что слишком высокий NOACK - 12 для моего мотора (audi AMB) и слишком скудный пакет присадок для 10 ткм по городу. Ноак дал шламу, и забитую ВКГ, а по окончанию работы присадок оксисление сформировало лак на валах ну и во всем двс видимо.
@kulay, "все дело в волшебных пузырьках"  :laugh:  в интервалах смены масла дело...
Куда-то пропал анализ свежего BP Visco 3000, добавлю потерянный.
Есть у BP на канистрах какая-нибудь защита от поделки? На что обращать внимания при покупке? Раньше у них была струйная маркировка на канистрах которую почему то у нас не научились поделывать.
Изменено пользователем Nessus
Масла ВР настолько непопулярные и нераскручены, что подделывать их не имеет смысла.
Ошибаетесь.
Выкладывал прайслисты "очень дешёвых" масел... Присутствует там BP
http://www.oil-club.ru/forum/topic/29036-chego-stoit-boyatsya/?view=getnewpost
@vital_xbc, Поделывают, в полный рост. Встречал как минимум две разновидности поделки, по запаху трансмисиока...
Был небольшой опыт эксплуатации  BP Visco 7000, катал это масло в 2000 годах на тазе с 1.5L v16. Проехал на нём без замены 18 ткм., залил его в зиму, зимой масло показало себя с наилучшей стороны, заморозить это масло способны только 50 градусные морозы, что выше то чепуха для этого масла, рассчитывал перед отпуском на юга заменить, но оно мне так понравилось, что поехал я на нём в отпуск, в итоге накатал 18 ткм. Двигатель все 18 ткм. тикал как часики с характерным для немецких двигателей 80-90 годов посвистыванием,даже соседи интересовались, какое масло льёшь? Но пришло время замены, залил эссо и охренел как двигатель на свежем эссо работает намного громче и жестче,начал цокать компенсатор, по всей видимости масло эссо подделка, пришлось опять менять масло. Короче говоря масло BP оставило очень тёплые воспоминания, не как не могу побороть желание попробовать его в 2ar-fe. Как думаете стоит его лить в этот двигатель?
Никаких противопоказаний не вижу. Попробуйте. Дорогое правда оно нынче стало...
@Nord_89, А у меня противоположный опыт. Накатал на нем 30ткм, 3 замены по 10ткм, оно постоянно угорало, а после вскрытия клапанной крышки увыяснил что масло оставило сильные осадки нагара и лака, в итоге сменил на Wolf. Правда речь не о 7000 а о 5000
vital_xbc kulay . Спасибо за ответы, выкатаю сои запасы масла, потом буду пробовать.
Не стоило по городу катать на 7000 аж 10т.км., тут на многих маслах может лак и нагар с перекатов вылезти. Катайте по городу не более 7т.км.
