Масла Aral
Масла Aral
Официальный сайт: http://www.aral-lubricants.com
Каталог масел: https://www.aral-lubricants.de/en/lubricants/aral-engine-oils/engine-oils-for-passenger-cars
Первый вариант кодов
Aral SuperTronic SAE 0W-40 1l - 20458
Aral SuperTronic SAE 0W-40 4l - 20459
Aral SuperTronic SAE 0W-40 60l - 10451
Aral SuperTronic SAE 0W-40 208l - 20450
Aral SuperTronic G SAE 0W-30  1l - 10382
Aral SuperTronic G SAE 0W-30 4l - 10383
Aral SuperTronic G SAE 0W-30 208l – 10385
Aral SuperTronic Longlife II SAE 0W-30 60l – 10321
Aral SuperTronic E SAE 0W-30 1l – 10508
Aral SuperTronic Longlife III SAE 5W-30 1l  - 20478
Aral SuperTronic Longlife III SAE 5W-30 4l - 20479
Aral SuperTronic Longlife III SAE 5W-30 60l - 10471
Aral SuperTronic Longlife III SAE 5W-30 208l – 20470
Aral HighTronic С SAE 5W-30 1l - 10589
Aral HighTronic С SAE 5W-30 4l – 10584
Aral HighTronic G SAE 5W-30 1l - 21387
Aral HighTronic G SAE 5W-30 4l - 21384
Aral HighTronic G SAE 5W-30 60l - 21381
Aral HighTronic G SAE 5W-30 208l  - 21380
Aral HighTronic J SAE 5W-30 1l - 20198
Aral HighTronic J SAE 5W-30 4l - 20194
Aral HighTronic J SAE 5W-30 60l - 20191
Aral HighTronic J SAE 5W-30 208l – 20190
Aral HighTronic R SAE 5W-30 1l - 16008
Aral HighTronic R SAE 5W-30 4l – 16004
Aral HighTronic F SAE 5W-30 1l - 10332
Aral HighTronic F SAE 5W-30 60l - 3692
Aral HighTronic F SAE 5W-30 208l – 10333
Aral ECOTronic F SAE 5W-20 1l - 25097
Aral ECOTronic F SAE 5W-20 4l – 25094
Aral MegaTronic SAE 10W-60 1l - 24927
Aral MegaTronic SAE 10W-60 4l – 10228
Aral HighTronic SAE 5W-40 1l - 20637
Aral HighTronic SAE 5W-40 4l - 20634
Aral HighTronic SAE 5W-40 5l - 20635
Aral HighTronic SAE 5W-40 20l - 20633
Aral HighTronic SAE 5W-40 60l - 20631
Aral HighTronic SAE 5W-40 208l – 20632
Aral HighTronic М SAE 5W-40 1l - 21407
Aral HighTronic М SAE 5W-40 4l - 21404
Aral HighTronic М SAE 5W-40 60l - 21401
Aral HighTronic М SAE 5W-40 208l – 21400
Aral BlueTronic SAE 10W-40 1l - 20488
Aral BlueTronic SAE 10W-40 4l - 20484
Aral BlueTronic SAE 10W-40 5l – 20485
Aral BlueTronic SAE 10W-40 20l - 10487
Aral BlueTronic SAE 10W-40 60l - 10481
Aral BlueTronic SAE 10W-40 208l -  20480
Aral SuperTurboral SAE 5W-30 4l - 11488
Aral SuperTurboral SAE 5W-30 20l - 11482
Aral SuperTurboral SAE 5W-30 208l – 11489
Aral SuperTurboral LA SAE 5W-30 20l - 20353
Aral SuperTurboral LA SAE 5W-30 60l - 20351
Aral SuperTurboral LA SAE 5W-30 208l – 20350
Aral MegaTurboral SAE 10W-40 5l - 10625
Aral MegaTurboral SAE 10W-40 20l - 13932
Aral MegaTurboral SAE 10W-40 60l - 13931
Aral MegaTurboral SAE 10W-40 208l – 23930
Aral MegaTurboral LA SAE 10W-40 20l - 13962
Aral MegaTurboral LA SAE 10W-40 208l – 13961
MegaTurboral VR SAE 10W-40 20l – 20203
MegaTurboral S SAE 10W-40 208l – 20131
Aral  Turboral SAE 10W-40 1l - 21197
Aral  Turboral SAE 10W-40 5l - 22004
Aral  Turboral SAE 10W-40 20l - 22003
Aral  Turboral SAE 10W-40 60l - 22001
Aral  Turboral SAE 10W-40 208l – 22000
Aral Turboral SAE 15W-40 5l - 22014
Aral Turboral SAE 15W-40 20l - 11281
Aral Turboral SAE 15W-40 208l – 22119
Aral Getriebeöl EP SYNTH. SAE 75W-90 1l – 25467
Aral Getriebeöl EP 85W-90 1l – 15108
Aral  Getriebeöl  EP Plus 80W-90 20l - 15452
Aral  Getriebeöl  EP Plus 80W-90 60l - 15454
Aral  Getriebeöl  EP Plus 80W-90 208l – 25450
Aral Getriebeöl HYP 85W-90 1l - 14257
Aral Getriebeöl HYP 85W-90 20l – 14303
Aral Getriebeöl BS LSX SAE 75W-140 20l – 26342
Aral Getriebeöl ATF 22 1l - 15973
Aral Getriebeöl ATF 22 20l – 15968
Aral Getriebeöl ATF 22 208l – 15970
Aral Getriebeöl ATF 55 1l - 15928
Aral Getriebeöl ATF 55 20l – 15922
Aral Getriebeöl ATF J 1l - 56638
Aral Getriebeöl ATF J 20l -  56633
Aral Getriebeöl ATF E-S 1l – 15878
Aral Antifreeze Extra 1l – 90829
Aral Antifreeze Silikatfrei 1l - 90839
Второй вариант кодов:
4003116106259 Моторное масло ARAL MegaTurboral SAE 10W-40 (5л)
4003116204597 Моторное масло ARAL SuperTronic SAE 0W-40 (4л)
4003116204849 Моторное масло ARAL BlueTronic SAE 10W-40 (4л)
4003116204887 Моторное масло ARAL BlueTronic SAE 10W-40 (1л)
4003116212745 Моторное масло ARAL Plus Turboral SAE 15W-40 (4л)
4003116103326 Моторное масло ARAL HighTronic F SAE 5W-30 (1л)
4003116220047 Моторное масло ARAL Turboral SAE 10W-40 (5л)
4003116220078 Моторное масло ARAL Turboral SAE 10W-40 (1л)
4003116220146 Моторное масло ARAL Turboral SAE 15W-40 (5л)
4008177991288 Моторное масло ARAL Turboral SAE 10W-40 (20л)
4003116105894 Моторное масло ARAL HighTronic C SAE 5W-30 (1л)
4003116114889 Моторное масло ARAL SuperTurboral SAE 5W-30 (4л)
4003116142578 Трансмиссионное масло ARAL Getriebeol Hyp SAE 85W-90 (1л)
4003116151082 Трансмиссионное масло ARAL Getriebeol EP SAE 85W-90 (1л)
4003116158784 Трансмиссионное масло ARAL Getriebeol ATF E-S (1л)
4003116159286 Трансмиссионное масло ARAL Getriebeol ATF 55 (1л)
4003116159736 Трансмиссионное масло ARAL Getriebeol ATF 22 (1л)
4003116160084 Моторное масло ARAL HighTronic R SAE 5W-30 (1л)
4003116201985 Моторное масло ARAL HighTronic J SAE 5W-30 (1л)
4003116213971 Моторное масло ARAL HighTronic M SAE 5W-30 (1л)
4003116566381 Трансмиссионное масло ARAL Getriebeol ATF J (1л)
4003116908297 Антифриз концентрированный бесцветный ARAL Antifreeze Extra (1л)
4003116908396 Антифриз концентрированный красный ARAL Antifreeze Silikatfrei (1л)
2200000013262 Моторное масло ARAL Extra Turboral SAE 10W-40 (20л)
2200000013682 Моторное масло ARAL SuperTurboral SAE 5W-30 (20л)
4008177965005 Гидравлическое масло ARAL Vitam DE 32 (20л)
4008177990809 Моторное масло ARAL Turboral SAE 15W-40 (20л)
4008177990175 Моторное масло ARAL MegaTurboral SAE 10W-40 (208л)
2200000013279 Моторное масло ARAL Extra Turboral SAE 10W-40 (60л)
2200000013330 Моторное масло ARAL MultiTurboral SAE 15W-40 (60л)
2200000013248 Моторное масло ARAL BlueTronic SAE 10W-40 (60л)
4008177991271 Моторное масло ARAL Turboral SAE 10W-40 (60л)
2200000013286 Моторное масло ARAL HighTronic SAE 5W-40 (60л)
4003116249246 Моторное масло ARAL MegaTronic SAE 10W-60 (4л)
4003116249277 Моторное масло ARAL MegaTronic SAE 10W-60 (1л)
4008177990182 Моторное масло ARAL Turboral SAE 10W-40 (208л)
4008177943706 Трансмиссионное масло ARAL Getriebeol Hyp Synth. SAE 75W-90 (60л)
4008177959646 Трансмиссионное масло ARAL Getriebeol EP Plus SAE 80W-90 (60л)
4008177964312 Трансмиссионное масло ARAL Getriebeol ATF J (20л)
4008177978890 Трансмиссионное масло ARAL Getriebeol ATF 55 (60л)
4008177990076 Моторное масло ARAL HighTronic SAE 5W-40 (208 л)
4008177990083 Моторное масло ARAL BlueTronic SAE 10W-40 (208л)
4008177990199 Моторное масло ARAL Turboral SAE 15W-40 (208л)
14AF79 BlueTronic 10W-40     20 Liter
154FE6 BlueTronic 10W-40     4 Liter
1529FA BlueTronic 10W-40     5 Liter
14955C BlueTronic 10W-40     60 Liter
14F736 BlueTronic 10W-40    1 Liter
14F738 BlueTronic 10W-40    208 Liter
15318F EcoTronic F 5W-20     1 Liter
15318C EcoTronic F 5W-20     208 Liter
15570E EcoTronic F 5W-20     4 Liter
15318D EcoTronic F 5W-20     60 Liter
1505B4 HighTronic 5W-40 1 Liter
151C11 HighTronic 5W-40 208 Liter
1505B1 HighTronic 5W-40 20 Liter
154FE7 HighTronic 5W-40 4 Liter
1505B2 HighTronic 5W-40 60 Liter
1529F9 HighTronic 5W-40     5 Liter
15B618 HighTronic C 5W-30     1 Liter
154F51 HighTronic C 5W-30     208 Liter
15563C HighTronic C 5W-30  4 Liter
15563B HighTronic C 5W-30     60 Liter
1552A0 HighTronic F  5W-30    1 Liter
15529D HighTronic F 5W-30    208 Liter
1552A2 HighTronic F 5W-30     4 Liter
15529F HighTronic F 5W-30     60 Liter
14FEEE HighTronic G 5W-30     1 Liter
14FEEC HighTronic G 5W-30     208 Liter
155EA7 HighTronic G 5W-30     4 Liter
14FEED HighTronic G 5W-30     60 Liter
14F90C HighTronic J  5W-30       60 Liter
14F90D HighTronic J  5W-30      208 Liter
151CED HighTronic J  5W-30     1 Liter
1555F7 HighTronic J 5W-30     4 Liter
150B6A HighTronic M 5W-40     1 Liter
150B6B HighTronic M 5W-40     208 Liter
154FE8 HighTronic M 5W-40     4 Liter
150B6C HighTronic M 5W-40     60 Liter
14F898 HighTronic R 5W-30       60 Liter
14F899 HighTronic R 5W-30      208 Liter
151CEE HighTronic R 5W-30     1 Liter
1555F2 HighTronic R 5W-30     4 Liter
154FAC MegaTronic 10W-60     1 Liter
15BC4F MegaTurboral 10W-40     208 Liter
15BC45 MegaTurboral 10W-40     20 Liter
15B6C8 MegaTurboral 10W-40     5 Liter
15BC50 MegaTurboral 10W-40 60 Liter
15BD3D MegaTurboral LA 10W-40     208 Liter
15BD3B MegaTurboral LA 10W-40     20 Liter
15AB04 MegaTurboral LA 10W-40     60 Liter
15BD42 MegaTurboral LA 10W-40   4 Liter
15567F MegaTurboral S 10W-40     208 Liter
15555A MegaTurboral S3 10W-40     208 Liter
15555B MegaTurboral S3 10W-40     60 Liter
1557B4 MegaTurboral VR 10W-40     208 Liter
1557B5 MegaTurboral VR 10W-40     20 Liter
1557B6 MegaTurboral VR 10W-40     60 Liter
151CA2 SuperTronic 0W-40 (Low SAPS)     208 Liter
14AF3B SuperTronic 0W-40 (Low SAPS)     20 Liter
14950C SuperTronic 0W-40 (Low SAPS)     60 Liter
14F800 SuperTronic 0W-40 (Low SAPS)    1 Liter
154FED SuperTronic 0W-40 (Low SAPS)    4 Liter
151CA3 SuperTronic E 0W-30     208 Liter
154FEE SuperTronic E 0W-30   4 Liter
149A1B SuperTronic E 0W-30     60 Liter
14F802 SuperTronic E 0W-30    1 Liter
15A8B0 SuperTronic G 0W-40     208 Liter
15A8AF SuperTronic G 0W-40     60 Liter
15A8AD SuperTronic G 0W-40    4 Liter
15A8AE SuperTronic G 0W-40    1 Liter
15135C SuperTronic Longlife III 5W-30     208 Liter
14AF40 SuperTronic LongLife III 5W-30     20 Liter
152A0E SuperTronic Longlife III 5W-30     5 Liter
14954B SuperTronic LongLife III 5W-30     60 Liter
14F7FD SuperTronic LongLife III 5W-30    1 Liter
15503C SuperTronic LongLife III 5W-30   4 Liter
15B6B5 SuperTronic LL IV FE 0W20 1 Liter
15B6B7 SuperTronic LL IV FE 0W20 208 Liter
15B6B6 SuperTronic LL IV FE 0W20 60 Liter
1556AA SuperTurboral  5W-30    208 Liter
1556A9 SuperTurboral  5W-30    20 Liter
1556AD SuperTurboral 5W-30     4 Liter
1556AC SuperTurboral 5W-30     60 Liter
15870F SuperTurboral LA 5W-30     208 Liter
15870E SuperTurboral LA 5W-30     20 Liter
15871F SuperTurboral LA 5W-30     4 Liter
15871A SuperTurboral LA 5W-30     60 Liter
15BCCA Turboral 10W-40      1 Liter
15BCD3 Turboral 10W-40      208 Liter
15BCD2 Turboral 10W-40      20 Liter
15BCD5 Turboral 10W-40      5 Liter
15BCD4 Turboral 10W-40      60 Liter
15BC5E Turboral 15W-40       20 Liter
15BC64 Turboral 15W-40       60 Liter
15BC61 Turboral 15W-40      208 Liter
15554B Turboral 15W-40      5 Liter
15B6C6 Turboral 15W-40     1 Liter
15569F Turboral 20W-20     208 Liter
15569E Turboral 20W-20     20 Liter
15BBD3 Turboral 20W-50     1 Liter
15BBD2    Turboral 20W-50     208 Liter
15BBD1    Turboral 20W-50     20 Liter
15BBD4 Turboral 20W-50     5 Liter
Aral HighTronic 5w40 API SL
Aral High Tronic 5W-40
Aral SuperTronic 0W-40
Aral SuperTronic G 0W-30
Aral SuperSynth 0W-40
Аral Ep Synth 75w-90 API GL-4/5
Aral Getriebeöle EP Synth 75W-90 API GL-4+
Aral Supertronic G 0W-30 отработка на Lada Granta после 4400км.
Аral Supеr Trоnic 0w-40 отработка на Lеxus после 11300км
а оно разве не одно и тоже. Где-то же проскакивала инфа, что весь сервисный Кастрол - это Арал и есть. И потому якобы сервисный кастрол лучше того, что для розницы идет, потому что не спецпродукт.
Попробую проанализировать в воскресенье эту инфу по тдсам и мсдсам какие найду.
Вот тут на Драйве заприметил. Человек ездит на Aral Megatronic 5W-50. Ссылка на источник - http://www.drive2.ru/cars/mercedes/e_class/e_class_w124/yuracoupe/journal/288230376152226148/#post
Интересно...Ждём
Интересно...Ждём
Постараюсь сегодня вечером (в районе 10 по мск) сесть, щас работа подвалила. Но если время будет постараюсь пораньше)
Ребят, кто нибудь подскажите ссылку где лежали спеки араловских масел, а то тут http://www.aral-lubricants.com/lubricants/com/automotive_lubricants/our_products.html мне пишет 404..
У меня такое было уже. Имхо у них сервер ложится периодически. К слову там еще блокирует если с одного ip по нескольким отделам шариться пытаешься, одновременно только на одном разделе сидеть позволяет.
да вроде тут все открыто -
http://www.aral.de/a...ntentId=7025259
О! Спасибо за ссыль, попробую завтра проанализиоровать
Хм.
ARAL SuperTronic Longlife III 5W-30 & SLX Professional Powerflow LongLife III 5W-30(English)
PP -42 / -42
Вязкость при 100 С 11.9 / 12.0
Вязкость при 40 С 69.41/ 70
Density 15C 0.852 / 0.8513
Flash point 234С (Open CUP) / 202 по DIN EN ISO 2719
Цифры НУ ОЧЕНЬ близкие. Кроме флешпоинта. У кастрола он ниже, но если у него показатель при другом типе тестирования то имхо масла близкие копии друг друга..
Для поклонников масел Арал. Вот вот на рынок Арал выпустит масло Aral HighTronic M 5W-40. Это будет НЕ малозольник. Собственно воть:
This product is a replacement of HighTronic M 5W-30 with the following specifications:
* ACEA A3/B3, A3/B4, API SN/CF
* MB-Freigabe 229.3/ 229.5 (now including Maybach and AMG motors)
* BMW LL01
* VW 502 00/505 00
* Porsche A40
* (to follow later: Renault RN0700/RN0710
Думаю неплохое маслицо должно быть, как выйдет на рынок обязательно попробую.
в мерсодопусках ужо присутствует) видел видел.
Думал оно уже продается :D
Интересно на хар-ки посмотреть. Судя по допускам, неплохое должно быть.
Судя из рекламных буклетов,то там указан 4 квартал 2011. Офф дилер сказал, что через пару недель должно появиться в продаже.
