Масло K1 Lube (Корея)
Официальный сайт: https://www.k1lube.com/
Сайт импортёра в РФ : https://k1lube.ru/
Видео: https://www.youtube.com/channel/UC6Ij3XQRUZyJ1yWrrBGE9rQ
TDS :   https://disk.yandex.ru/client/disk/TDS K1 Lube
8801471215014    K0512AL1W1    K1 Lube GX SP 0W-20_1L (1L*12)
8801471215076    K051244TW1    K1 Lube GX SP 0W-20_4LT (4LT*4)
8801471215212    K2512AL1W1    K1 Lube GX SP 5W-20_1L (1L*12)
8801471215311    K3512AL1W1    K1 Lube GX SP 5W-30_1L (1L*12)
8801471215373    K351244TW1    K1 Lube GX SP 5W-30_4LT (4LT*4)
8801471215342    K3512440W1    K1 Lube GX SP 5W-30_4L (4L*4)
8801471215359    K3512350W1    K1 Lube GX SP 5W-30_5L (5L*3)
8801471215410    K4512AL1W1    K1 Lube GX SP 5W-40_1L (1L*12)
8801471215472    K451244TW1    K1 Lube GX SP 5W-40_4LT (4LT*4)
8801471215441    K4512440W1    K1 Lube GX SP 5W-40_4L (4L*4)
8801471215458    K4512350W1    K1 Lube GX SP 5W-40_5L (5L*3)
8801471215717    K7512AL1W1    K1 Lube GX SP 10W-40_1L (1L*12)
8801471215779    K751244TW1    K1 Lube GX SP 10W-40_4LT (4LT*4)
8801471215748    K7512440W1    K1 Lube GX SP 10W-40_4L (4L*4)
8801471215755    K7512350W1    K1 Lube GX SP 10W-40_5L (5L*3)
8801471206111    K1602AL1W1    K1 Lube HD CI-4 10W-40_1L (1L*12)
8801471206173    K160244TW1    K1 Lube HD CI-4 10W-40_4LT (4LT*4)
8801471206142    K1602440W1    K1 Lube HD CI-4 10W-40_4L (4L*4)
8801471206159    K1602350W1    K1 Lube HD CI-4 10W-40_5L (5L*3)
8801471206166    K1602360W1    K1 Lube HD CI-4 10W-40_6L (6L*3)
8801471206197    K1602P20W1    K1 Lube HD CI-4 10W-40_20L
8801471206210    K2602AL1W1    K1 Lube HD CI-4 15W-40_1L (1L*12)
8801471206272    K260244TW1    K1 Lube HD CI-4 15W-40_4LT (4LT*4)
8801471206241    K2602440W1    K1 Lube HD CI-4 15W-40_4L (4L*4)
8801471206258    K2602350W1    K1 Lube HD CI-4 15W-40_5L (5L*3)
8801471206265    K2602360W1    K1 Lube HD CI-4 15W-40_6L (6L*3)
8801471206296    K2602P20W1    K1 Lube HD CI-4 15W-40_20L
8801471564167    K3745360W1    K1 Lube HD CH-4 15W-40_6L (6L*3)
8801471200119    K1002AL1W1    K1 Lube HD CF-4 15W-40_1L (1L*12)
8801471200140    K1002440W1    K1 Lube HD CF-4 15W-40_4L (4L*4)
8801471200157    K1002350W1    K1 Lube HD CF-4 15W-40_5L (5L*3)
8801471200164    K1002360W1    K1 Lube HD CF-4 15W-40_6L (6L*3)
8801471200195    K1002P20W1    K1 Lube HD CF-4 15W-40_20L
8801471250916    K9052AL1W1    K1 Lube ATF DX-III_1L (1L*12)
8801471250978    K905244TW1    K1 Lube ATF DX-III_4LT (4LT*4)
8801471252415    K4252AL1W1    K1 Lube ATF DX-VI_1L (1L*12)
8801471252477    K425244TW1    K1 Lube ATF DX-VI_4LT (4LT*4)
8801471251814    K8152AL1W1    K1 Lube ATF Multi_1L (1L*12)
8801471251876    K815244TW1    K1 Lube ATF Multi_4LT (4LT*4)
8801471251913    K9152AL1W1    K1 Lube CVTF_1L (1L*12)
8801471251975    K915244TW1    K1 Lube CVTF_4LT (4LT*4)
8801471252019    K0252AL1W1    K1 Lube DCTF_1L (1L*12)
8801471252071    K025244TW1    K1 Lube DCTF_4LT (4LT*4)
8801471296211    K2692AL1W1    K1 Lube Gear GL-5 75W-90_1L (1L*12)
8801471296242    K2692440W1    K1 Lube Gear GL-5 75W-90_4L (4L*4)
8801471296297    K2692P20W1    K1 Lube Gear GL-5 75W-90_20L
8801471298314    K3892AL1W1    K1 Lube Gear GL-5 80W-90_1L (1L*12)
8801471298345    K3892440W1    K1 Lube Gear GL-5 80W-90_4L (4L*4)
8801471298390    K3892P20W1    K1 Lube Gear GL-5 80W-90_20L
8801471298413    K4892AL1W1    K1 Lube Gear GL-5 85W-140_1L (1L*12)
8801471298444    K4892440W1    K1 Lube Gear GL-5 85W-140_4L (4L*4)
8801471298499    K4892P20W1    K1 Lube Gear GL-5 85W-140_20L
8801471366396    K3663P20W1    K1 Lube Hydraulic HL-46_20L
8801471366495    K4663P20W1    K1 Lube Hydraulic HL-68_20L
8801471368598    K5863P20W1    K1 Lube Hydraulic HM-46_20L
8801471368697    K6863P20W1    K1 Lube Hydraulic HM-68_20L
(пока нет)
Изменено пользователем Informed
Эу эу . Тут уже тесновато ) .
Опять Корейцы что то изобрели  фантазеры.
Ждали именно этого .....Кей Ван ?
канистры и банки у Kixx'а забираете и этикетки перерисовываете?
Топ менеджеры бы не смогли, так в наглую, содрать дизайн канистры с прошлой работы.
Кто бы с ними потом работал после этого? :laugh: Наверное какие то договора и отношения, все равно связывают... Ну этика там. :D
Можно адрес завода где делается в Юж. Корее это масло?
51 минуту назад, Informed сказал:
Не может он тут быть сделан, явно сделан на киксе.
Мутят, чтобы снизить напор от санкций - там же шеврон в учередосах, вероятно на него давят.
Изменено пользователем Exvision
Цитата
 просто топ-менеджеры из KIXX ушли и запустили свой бренд.
может их просто уволили....кто будет уходить с насиженного места х.з. куда.
2 минуты назад, Golfreef сказал:
да мне кажется так же как Nokian стал IKON, так же KIXX стал K1Lube
1 минуту назад, Exvision сказал:
почему тогда Zic не становится Kizz, a S-oil не становиться Liso'м ...ну и т.д.
21 минуту назад, Golfreef сказал:
потому что у зика нет шеврона в учередителях
http://www.zeusoil.co.kr/Default.htm делает вот такие масла ZEO http://www.zeolub.co.kr/main.htm
Этот производитель?
1 час назад, Golfreef сказал:
1 час назад, Exvision сказал:
MSDS_K1 Lube GX SP 5W-30.pdf
